Yes, only 942 mm. I used 10 braces, as that’s what the future larger gantry will be using, and trying to include numbers of braces in the parameters was just a little too complicated for me at the moment.
Next version should be about 52-60”
Here’s a screen shot showing what the X belt would look like with the smaller logo like on Johnathan’s.
And here’s a DXF of that design.
Well now that the Christmas madness has subsided a bit, it’s time to get back to the LR3 build again.
I did manage to make a bit of progress over the last few weeks…
First of all, I upgraded the flat-ish table from a single sheet of plywood to a 63" x 120" framed table top (see post 68 in Table Ideas for those just getting started - #68 by Bartman)
When I was at the lumber store picking out the 10’ 2x4s for the table build, I noticed a bunch of full sheets of 3/16" and 1/4" hardboard sitting at the bottom of a pile of used cardboard. I asked the yard attendant about them, and he told me that they were scrap, and I could take them for free if I wanted. SCORE! One was a bit nicked on a couple of edges, but they are perfect for test cuts, possibly for cutting out struts (I was planning on using aluminum, but hey, free!), and possibly even for use as the lower skin on a future torsion table.
Next up was to sort out the dust collection. I have a built-in vacuum system in my house, and the canister is located in my garage/workshop, with an auxiliary inlet and a 50’ hose already available. The only thing missing was how to connect it to the LR3, as the hose was several mm smaller than the stock V1E dust shoe. I looked around the forums and didn’t find exactly what I was looking for (or maybe I did, but just didn’t recognize it at the time), so I delved into Fusion 360 and figured out how to design and print my own. Confused about Vacuum Hose Sizes
When I was building the table. I needed to make some straight cuts in the plywood, and trying to manhandle it through my cheap-ass table saw by myself seemed pretty sketchy, so I bought a couple of 24"x96" pieces of 1/2" styrofoam to lay on the garage floor, and used a circular saw with a straight edge clamped as a guide. It worked great, so I thought that I could re-purpose the foam sheets as a temporary (ish) spoil board, at least until I get the full sheet version of the LR3 built. I used 1" decking screws through the hardboard and the foam to secure the work stock to the table.
So that is the table and LR3 pretty much all set up to make the first cuts.
I figured that the struts should be the first thing made on the machine, so I spent some time sorting out nesting and arranging the different strut versions into a single file that I could put into EstlCAM and create the toolpaths.
I tried using DeepNest to arrange all of the DXF files onto a single sheet, but it turns out that the text all had very tiny gaps that EstlCAM didn’t worry about, but that DeepNest did. So I ended up just importing the files into EstlCAM individually, and used the Move tools to line them up. (I later found a Fusion 360 Add On called Fill Gaps that will correct all of the errors so that DeepNest can use the files).
I’ve made an air cut with the resulting gcode file, and tweaked it a bit to increase the travel speeds and to reduce the Z Clearance between moves, which shaved the time down by about 35%.
Hopefully tomorrow I can post pictures of the cut out hardboard struts. Then everything needs to be packed away so that I can get the car into the garage for a much needed brake job.
Hurray! The inaugural cut on my LR3 (Little Red version) is complete!
A couple of things I will keep in mind for the next cut:
That’s all for now, time to disassemble and store everything away so that I can get my garage back to do some car repairs.
I’ve found that this cleans up nicely with a quick pass of 220 grit sandpaper by hand. Way easier than I expected.
With a finishing pass and an extremely quick touch of sandpaper that goes right away. As you dial in your cuts it will get significantly less as well. Down cut bits are not much fun.
That was with a finishing pass at 0.35mm and 2400 mm/min (initial pass 3.18mm and 1800 mm.min). It did leave it fairly fuzzy, but…
did clear up the fuzz from the outer edges and most of the top surface. There is still a bit left on the inner edges (text and holes), and getting into all of the nooks and crannies is a bit finicky.
I’m hoping so, although I’m not planning on too many more hardboard cuts in the future, mostly thick plywood and thin to medium (9 mm) aluminum. (Probably will use hardboard as test cuts for those).
I’m curious. Can you please elaborate?
Ryan can answer of course. I would just mention, they do the opposite of evacuating the chips out of the slot. They are pressing the chips into the slot.
Yes, I understand that chip evacuation is an issue with downcut. just didn’t think that it would be a huge issue with a total DOC of around 3mm. Am I mistaken about that?
Probably not mistaken. My experience with cutting hardboard was the same: fuzzies, sanded off. I think it’s what pretty much everyone gets with cutting hardboard. It’s got its own characteristics.
Downcut bits can clog easily when doing a contour cut
Even if you’re making 3mm DOC passes, in the end you end up cutting the whole thickness of material, and dust accumulates into the slot
This accumulated dust will pack and make a hard aggregation when it’s pushed by the bit, causing missed steps and failed cuts ![]()
When using a downcut bit, make sure you have a large roughing pass, so that the slot is as wide as 2 times the bit’s diameter, this will leave the dust a place to go…
Also, I found reversing the vac and using it in “blower” mode can help disperse the dust quite a bit, although it’s very messy ![]()
Just my 2 cents. I typically will start deep slots or pockets with a down cut bit for a pass at 1 mm for clean edges and little to no fuzzies. Then I switch to an upcut bit to finish. While it takes a bit change, the cleaner edges pays for itself with less sanding afterwards.
Its a two flute so not super well suited for our RPm, the chips pack down so you have to cut slower. I would try other materials before you switch to downcuts.
This accumulated dust will pack and make a hard aggregation…
I understand what you are saying, and my initial thoughts were to use a downcut bit in very limited circumstances, specifically only with 3mm hardboard, where the total slot depth only requires a single cut, and only to reduce the “fuzz”,. So I thought that the slot wouldn’t be very deep, and that perhaps dust accumulation might not be too much of an issue in this specific application, but…
Its a two flute so not super well suited for our RPM…
This to me is a very compelling argument, and a very good point. I would have to slow the router way down and speed the feed rate way up to maintain the same chip load, probably hitting the machine limits on both variables.
So it looks like single flute and sandpaper going forward.
Thanks for the feedback all!
Chiming in to muddy the water. I have used two flute downcut bits on 12mm ply a lot . Two passes at 6.25 DOC without tabs. The chips would pack into the cut and hold the parts in place. The time saved was worth any shorter life of the endmill for me.
I find this use case highly intriguing…
It’s what I used when I was selling these: Plant Stands
I didn’t want to trim tabs and was cutting full nested 4x8 sheets of them. It was a real time saver for me.
Well two months later…
Since my last post here I have finished working on the cars, and managed to get a bit of progress on my LR3 build:
It makes a huge difference in being able to move the LR3 out of the way so that I can get the cars in the garage when needed. Link to the thread is here.
The hardboard has a LOT of flex, so my plan is to cut out some blank struts from 3mm aluminum sheet (salvaged signs) and place them behind the hardboard struts. I also want to paint the struts (probably black on the aluminum and red on the hardboard, to provide a contrast for the lettering), but that can wait for now.
I also put some epoxy on all of the non-captured nuts, so that adding the aluminum backing hopefully won’t be too much of a PITA.
I used @DougJoseph’s kinematic tool holder (modified with @jamiek’'s “mountains and valleys” fixed and mobile parts), and Doug’s Air Mist Attachment (Side mount version model B). For more info you can check out this thread.
I still have a few bits and bobs to mount the air hose system to the table (valves, elbows, etc), and I had a couple of hiccups with printing the tool holder (post #200 in the tool holder thread), but overall it works great!
I had a bit of an issue where the outside of the prints were very close to the design value, but the inside of the print (hole) was about 0.5mm too small. I used post-processing (sandpaper) to make it work, but it looks like I need to go into Cura and play around with the “Hole Horizontal Expansion”" settings.
Coming up - I bought some 9mm aluminum for the YZ plates, and I scrounged a bunch of 6mm aluminum for the XZ plates, and now that I have the air mist system up and running, I’m working on setting up the files in Estlcam to cut those items. I’ll probably do some test cuts with the 3mm aluminum for the strut backing first, but I need to finish removing the vinyl and adhesive from the old signs before I start that.
Whew, that seems like a lot of progress!
