Routing aluminum
Machining 1/8" aluminum
Does anyone have any experience/ thoughts on machining aluminum sheets. I’ve been making a lot of stuff with 14" hardwood and it has a tendency to work. I was thinking I could laminate the thin hardwood with an aluminum backing sheet. Any ideas would be helpful
There are quite a few topics here. I am exclusively using trochoidal milling for it, Jonathan doesn’t. :smile:
I went through the process when cutting some old signs (2mm aluminum) for my struts.
Suggestions:
  • Trochoidal milling as suggested is great, especially for thicker material, although if you are cutting very thin (2mm or less) sheet, it is possible to use straight milling instead. Trochoidal is VERY slow in comparison.
  • An Air-Mist sprayer using IsoPropyl Alcohol (IPA) for cooling of the end mill and chip evacuation is helpful
  • Aluminum is very sticky, so it is easy to weld chips to your end mill. Feeds and speeds to ensure no rubbing are critical (as is chip evacuation)
You can check out my build thread, starting at the linked post, and then for the next 5 or 6 posts for some info on the setup, feeds and speeds, etc. that I used.
This thread has some info on the Air-Mist system, with a few links to threads about cutting aluminum and making a holder to attach the sprayer to the LR3.
Amazon has a ton of the sprayers for a pretty cheap price. IPA is available at most pharmacies, or even Costco.
And if you don’t have an air mist system and don’t want to melt the chips your are can at trochoidal. :yum:
I have a thread around here somewhere detailing a good beginner trochoidal setup……
Edit: Found it…
Anyone have Alu carving (e.g. 90 degree bit) settings that worked for them?
I tried it once or twice and never got good results. If you figure it out please let me know lol
