I’m trying to add the Wifi to my CNC. I’ve sucessufully flash the ESP01S, I can access and configure the web interface.
In the “files panel”, I’m able to upload files. But I’m not able to access the SD, TFT SD, TFT USB. I can access these storage from my TFT… But not from the web page. I’m always getting a message “error” in the botom of the panel. I can see a “M20 U:/”, “M20 SD:/” or “M20 M21” in the terminal panel, butting nothing other…
Some one has been able to use it? Any idea how to fix it?
Are you using the SD card in the TFT for the files? You should be.
Also wireless transfers are very shaky, it is best to still transfer them directly to the card. The interface is best just for control, not file transfers. It is very slow.
Yes, I’m using the SD card in the TFT. I have tried with an SD card in the TFT, a micro SD in the main board and a USB key in the TFT. All of them separatly
No one is working through the web server. But all of them are working through the TFT screen when I click on print.
I have tried to insert the SD card or USB key before or after the board has been powered up.
I really do not know of any troubleshooting. If all the setting seem right to you maybe you got a bad ESP chip.
Everything works except seeing any files…Do you have the gray and black cables attached to your TFT screen and the SKR? Do both the marlin and the touch side of the tft see the files on the SD card? If they do I assume the esp is bad.
