Hey Jefe,
In my first thread you also mentioned digipot, I didn’t understand it at the time but I still don’t know what you meant by it. Could you have a look again please?
In ‘Configuration_adv.h’ is where I find the settings of digipots, btw how do I post the code like you do in the other thread?:
@section stepper motor current
Some boards have a means of setting the stepper motor current via firmware.
The power on motor currents are set by:
PWM_MOTOR_CURRENT - used by MINIRAMBO & ULTIMAIN_2
known compatible chips: A4982 -
DIGIPOT_MOTOR_CURRENT - used by BQ_ZUM_MEGA_3D, RAMBO & SCOOVO_X9H
known compatible chips: AD5206 -
DAC_MOTOR_CURRENT_DEFAULT - used by PRINTRBOARD_REVF & RIGIDBOARD_V2
known compatible chips: MCP4728 -
DIGIPOT_I2C_MOTOR_CURRENTS - used by 5DPRINT, AZTEEG_X3_PRO, AZTEEG_X5_MINI_WIFI, MIGHTYBOARD_REVE
known compatible chips: MCP4451, MCP4018 -
Motor currents can also be set by M907 - M910 and by the LCD.
M907 - applies to all.
M908 - BQ_ZUM_MEGA_3D, RAMBO, PRINTRBOARD_REVF, RIGIDBOARD_V2 & SCOOVO_X9H
M909, M910 & LCD - only PRINTRBOARD_REVF & RIGIDBOARD_V2
//#define PWM_MOTOR_CURRENT { 1300, 1300, 1250 } // Values in milliamps
#define DIGIPOT_MOTOR_CURRENT { 138,138,138,138,138 } // Values 0-255 (RAMBO 135 = ~0.75A, 185 = ~1A)
//#define DAC_MOTOR_CURRENT_DEFAULT { 70, 80, 90, 80 } // Default drive percent - X, Y, Z, E axis
// Use an I2C based DIGIPOT (e.g., Azteeg X3 Pro)
//#define DIGIPOT_I2C
#if ENABLED(DIGIPOT_I2C) && !defined(DIGIPOT_I2C_ADDRESS_A)
Common slave addresses:
A (A shifted) B (B shifted) IC -
Smoothie 0x2C (0x58) 0x2D (0x5A) MCP4451
AZTEEG_X3_PRO 0x2C (0x58) 0x2E (0x5C) MCP4451
AZTEEG_X5_MINI 0x2C (0x58) 0x2E (0x5C) MCP4451
AZTEEG_X5_MINI_WIFI 0x58 0x5C MCP4451
MIGHTYBOARD_REVE 0x2F (0x5E) MCP4018
#define DIGIPOT_I2C_ADDRESS_A 0x2C // unshifted slave address for first DIGIPOT
#define DIGIPOT_I2C_ADDRESS_B 0x2D // unshifted slave address for second DIGIPOT
#endif
//#define DIGIPOT_MCP4018 // Requires library from GitHub - stawel/SlowSoftI2CMaster
#define DIGIPOT_I2C_NUM_CHANNELS 8 // 5DPRINT: 4 AZTEEG_X3_PRO: 8 MKS SBASE: 5
// Actual motor currents in Amps. The number of entries must match DIGIPOT_I2C_NUM_CHANNELS.
// These correspond to the physical drivers, so be mindful if the order is changed.
#define DIGIPOT_I2C_MOTOR_CURRENTS { 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0 } // AZTEEG_X3_PRO
