Kill() called
-SKR-PRO-V1.2 purchased from ali express
-24V Power supply
-No limit switches connected
-When I press the manual jog on Repetier Host V2.3.1 and on the display the motors turn a fuzz then stop and I get the Error: Printer halted. kill() called!
I have tried both the end stop firmware and the non endstop firmware. Also tried with the display disconnected. Same Error
New to the SKR-PRO-V1.2 have an older MPCNC with Ramps1.4 but never got it running in a way I was happy with giving it another attempt.
18:00:20.728 : FIRMWARE_NAME:Marlin 515S 2.1.1 (Sep 25 2022 17:41:37) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1CNC 515S EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
18:00:20.728 : Cap:SERIAL_XON_XOFF:0
18:00:20.728 : Cap:BINARY_FILE_TRANSFER:0
18:00:20.728 : Cap:EEPROM:1
18:00:20.728 : Cap:VOLUMETRIC:1
18:00:20.728 : Cap:AUTOREPORT_POS:1
18:00:20.728 : Cap:AUTOREPORT_TEMP:1
18:00:20.728 : Cap:PROGRESS:0
18:00:20.728 : Cap:PRINT_JOB:1
18:00:20.728 : Cap:AUTOLEVEL:0
18:00:20.728 : Cap:RUNOUT:0
18:00:20.728 : Cap:Z_PROBE:0
18:00:20.728 : Cap:LEVELING_DATA:0
18:00:20.728 : Cap:BUILD_PERCENT:0
18:00:20.728 : Cap:SOFTWARE_POWER:0
18:00:20.728 : Cap:TOGGLE_LIGHTS:0
18:00:20.728 : Cap:CASE_LIGHT_BRIGHTNESS:0
18:00:20.728 : Cap:EMERGENCY_PARSER:1
18:00:20.728 : Cap:HOST_ACTION_COMMANDS:1
18:00:20.728 : Cap:PROMPT_SUPPORT:1
18:00:20.728 : Cap:SDCARD:1
18:00:20.728 : Cap:MULTI_VOLUME:0
18:00:20.728 : Cap:REPEAT:0
18:00:20.728 : Cap:SD_WRITE:1
18:00:20.728 : Cap:AUTOREPORT_SD_STATUS:1
18:00:20.728 : Cap:LONG_FILENAME:0
18:00:20.728 : Cap:LFN_WRITE:0
18:00:20.728 : Cap:CUSTOM_FIRMWARE_UPLOAD:0
18:00:20.728 : Cap:EXTENDED_M20:0
18:00:20.728 : Cap:THERMAL_PROTECTION:1
18:00:20.728 : Cap:MOTION_MODES:1
18:00:20.728 : Cap:ARCS:1
18:00:20.728 : Cap:BABYSTEPPING:1
18:00:20.759 : Cap:CHAMBER_TEMPERATURE:0
18:00:20.759 : Cap:COOLER_TEMPERATURE:0
18:00:20.759 : Cap:MEATPACK:0
18:00:20.759 : Cap:CONFIG_EXPORT:0
18:00:20.759 : area:{full:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}},work:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}}}
18:00:20.759 : X:0.0000 Y:0.0000 Z:0.0000 E:0.0000 Count X:0 Y:0 Z:0
18:00:20.759 : echo:DEBUG:INFO,ERRORS
18:00:20.759 : echo:No media
18:00:20.759 : echo:Unknown command: "M80"
18:00:42.812 : X driver error detected: 0x801600E0
18:00:42.812 : coil short circuit
18:00:42.812 : X	Y	Z
18:00:42.812 : Address		0	0	0
18:00:42.843 : Enabled		true	false	false
18:00:42.843 : Set current	900	900	900
18:00:42.875 : RMS current	887	887	887
18:00:42.906 : MAX current	1251	1251	1251
18:00:42.906 : Run current	28/31	28/31	28/31
18:00:42.906 : Hold current	22/31	22/31	22/31
18:00:42.922 : CS actual	22/31	22/31	22/31
18:00:42.922 : PWM scale
18:00:42.953 : vsense		1=.18	1=.18	1=.18
18:00:42.968 : stealthChop	false	false	false
18:00:43.000 : msteps		16	16	16
18:00:43.015 : interp		true	true	true
18:00:43.047 : tstep		max	max	max
18:00:43.047 : PWM thresh.
18:00:43.047 : [mm/s]
18:00:43.062 : OT prewarn	false	false	false
18:00:43.062 : triggered
18:00:43.062 : OTP		false	false	false
18:00:43.093 : pwm scale sum	25	25	25
18:00:43.125 : pwm scale auto	0	0	0
18:00:43.140 : pwm offset auto	36	36	36
18:00:43.172 : pwm grad auto	14	14	14
18:00:43.187 : off time	3	3	3
18:00:43.218 : blank time	24	24	24
18:00:43.218 : hysteresis
18:00:43.250 : -end		-1	-1	-1
18:00:43.265 : -start		1	1	1
18:00:43.265 : Stallguard thrs	0	0	0
18:00:43.297 : uStep count	376	120	120
18:00:43.297 : DRVSTATUS	X	Y	Z
18:00:43.328 : sg_result	0	0	0
18:00:43.343 : stst
18:00:43.375 : olb		*	*	*
18:00:43.406 : ola		*	*	*
18:00:43.422 : s2gb
18:00:43.453 : s2ga
18:00:43.468 : otpw
18:00:43.500 : ot
18:00:43.531 : 157C
18:00:43.547 : 150C
18:00:43.578 : 143C
18:00:43.593 : 120C
18:00:43.625 : s2vsa
18:00:43.640 : s2vsb		*
18:00:43.640 : Driver registers:
18:00:43.656 : X	0x80:16:00:E0
18:00:43.656 : Y	0x80:16:00:C0
18:00:43.672 : Z	0x80:16:00:C0
18:00:43.672 : echo:Driver error
18:00:43.711 : Error:Printer halted. kill() called!
18:00:43.712 : //action:poweroff
18:18:51.001 : No start signal detected - forcing start
18:18:51.033 : FIRMWARE_NAME:Marlin 515S 2.1.1 (Sep 25 2022 17:41:37) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1CNC 515S EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
18:18:51.033 : Cap:SERIAL_XON_XOFF:0
18:18:51.033 : Cap:BINARY_FILE_TRANSFER:0
18:18:51.034 : Cap:EEPROM:1
18:18:51.034 : Cap:VOLUMETRIC:1
18:18:51.034 : Cap:AUTOREPORT_POS:1
18:18:51.034 : Cap:AUTOREPORT_TEMP:1
18:18:51.034 : Cap:PROGRESS:0
18:18:51.034 : Cap:PRINT_JOB:1
18:18:51.034 : Cap:AUTOLEVEL:0
18:18:51.034 : Cap:RUNOUT:0
18:18:51.034 : Cap:Z_PROBE:0
18:18:51.034 : Cap:LEVELING_DATA:0
18:18:51.034 : Cap:BUILD_PERCENT:0
18:18:51.034 : Cap:SOFTWARE_POWER:0
18:18:51.034 : Cap:TOGGLE_LIGHTS:0
18:18:51.034 : Cap:CASE_LIGHT_BRIGHTNESS:0
18:18:51.034 : Cap:EMERGENCY_PARSER:1
18:18:51.034 : Cap:HOST_ACTION_COMMANDS:1
18:18:51.034 : Cap:PROMPT_SUPPORT:1
18:18:51.034 : Cap:SDCARD:1
18:18:51.034 : Cap:MULTI_VOLUME:0
18:18:51.034 : Cap:REPEAT:0
18:18:51.034 : Cap:SD_WRITE:1
18:18:51.034 : Cap:AUTOREPORT_SD_STATUS:1
18:18:51.034 : Cap:LONG_FILENAME:0
18:18:51.034 : Cap:LFN_WRITE:0
18:18:51.034 : Cap:CUSTOM_FIRMWARE_UPLOAD:0
18:18:51.034 : Cap:EXTENDED_M20:0
18:18:51.034 : Cap:THERMAL_PROTECTION:1
18:18:51.034 : Cap:MOTION_MODES:1
18:18:51.034 : Cap:ARCS:1
18:18:51.034 : Cap:BABYSTEPPING:1
18:18:51.034 : Cap:CHAMBER_TEMPERATURE:0
18:18:51.034 : Cap:COOLER_TEMPERATURE:0
18:18:51.034 : Cap:MEATPACK:0
18:18:51.034 : Cap:CONFIG_EXPORT:0
18:18:51.035 : area:{full:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}},work:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}}}
18:18:51.039 : X:0.0000 Y:0.0000 Z:0.0000 E:0.0000 Count X:0 Y:0 Z:0
18:18:51.039 : echo:DEBUG:INFO,ERRORS
18:18:51.039 : echo:No media
18:18:51.039 : echo:Unknown command: "M80"
18:19:09.491 : X driver error detected: 0x801600E0
18:19:09.491 : coil short circuit
18:19:09.491 : X	Y	Z
18:19:09.491 : Address		0	0	0
18:19:09.522 : Enabled		true	false	false
18:19:09.522 : Set current	900	900	900
18:19:09.553 : RMS current	887	887	887
18:19:09.569 : MAX current	1251	1251	1251
18:19:09.569 : Run current	28/31	28/31	28/31
18:19:09.569 : Hold current	22/31	22/31	22/31
18:19:09.600 : CS actual	22/31	22/31	22/31
18:19:09.600 : PWM scale
18:19:09.631 : vsense		1=.18	1=.18	1=.18
18:19:09.647 : stealthChop	false	false	false
18:19:09.678 : msteps		16	16	16
18:19:09.694 : interp		true	true	true
18:19:09.725 : tstep		max	max	max
18:19:09.725 : PWM thresh.
18:19:09.725 : [mm/s]
18:19:09.741 : OT prewarn	false	false	false
18:19:09.741 : triggered
18:19:09.741 : OTP		false	false	false
18:19:09.772 : pwm scale sum	25	25	25
18:19:09.788 : pwm scale auto	0	0	0
18:19:09.819 : pwm offset auto	36	36	36
18:19:09.850 : pwm grad auto	14	14	14
18:19:09.866 : off time	3	3	3
18:19:09.897 : blank time	24	24	24
18:19:09.897 : hysteresis
18:19:09.913 : -end		-1	-1	-1
18:19:09.944 : -start		1	1	1
18:19:09.944 : Stallguard thrs	0	0	0
18:19:09.960 : uStep count	504	56	56
18:19:09.960 : DRVSTATUS	X	Y	Z
18:19:09.991 : sg_result	0	0	0
18:19:10.022 : stst
18:19:10.053 : olb		*	*	*
18:19:10.069 : ola		*	*	*
18:19:10.100 : s2gb
18:19:10.116 : s2ga
18:19:10.151 : otpw
18:19:10.163 : ot
18:19:10.195 : 157C
18:19:10.210 : 150C
18:19:10.241 : 143C
18:19:10.257 : 120C
18:19:10.288 : s2vsa
18:19:10.319 : s2vsb		*
18:19:10.319 : Driver registers:
18:19:10.319 : X	0x80:16:00:E0
18:19:10.335 : Y	0x80:16:00:C0
18:19:10.335 : Z	0x80:16:00:C0
18:19:10.335 : echo:Driver error
18:19:10.383 : Error:Printer halted. kill() called!
18:19:10.383 : //action:poweroff
18:22:22.437 : Communication timeout - reset send buffer block
18:27:16.990 : No start signal detected - forcing start
18:27:17.004 : Error:Line Number is not Last Line Number+1, Last Line: 0
18:27:17.005 : Resend: 1
18:27:17.032 : echo:Unknown command: ""
18:27:17.061 : FIRMWARE_NAME:Marlin 515S 2.1.1 (Sep 25 2022 17:41:37) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1CNC 515S EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
18:27:17.061 : Cap:SERIAL_XON_XOFF:0
18:27:17.061 : Cap:BINARY_FILE_TRANSFER:0
18:27:17.062 : Cap:EEPROM:1
18:27:17.062 : Cap:VOLUMETRIC:1
18:27:17.062 : Cap:AUTOREPORT_POS:1
18:27:17.062 : Cap:AUTOREPORT_TEMP:1
18:27:17.062 : Cap:PROGRESS:0
18:27:17.062 : Cap:PRINT_JOB:1
18:27:17.062 : Cap:AUTOLEVEL:0
18:27:17.062 : Cap:RUNOUT:0
18:27:17.063 : Cap:Z_PROBE:0
18:27:17.063 : Cap:LEVELING_DATA:0
18:27:17.063 : Cap:BUILD_PERCENT:0
18:27:17.063 : Cap:SOFTWARE_POWER:0
18:27:17.063 : Cap:TOGGLE_LIGHTS:0
18:27:17.063 : Cap:CASE_LIGHT_BRIGHTNESS:0
18:27:17.063 : Cap:EMERGENCY_PARSER:1
18:27:17.063 : Cap:HOST_ACTION_COMMANDS:1
18:27:17.063 : Cap:PROMPT_SUPPORT:1
18:27:17.063 : Cap:SDCARD:1
18:27:17.063 : Cap:MULTI_VOLUME:0
18:27:17.063 : Cap:REPEAT:0
18:27:17.063 : Cap:SD_WRITE:1
18:27:17.063 : Cap:AUTOREPORT_SD_STATUS:1
18:27:17.063 : Cap:LONG_FILENAME:0
18:27:17.063 : Cap:LFN_WRITE:0
18:27:17.063 : Cap:CUSTOM_FIRMWARE_UPLOAD:0
18:27:17.063 : Cap:EXTENDED_M20:0
18:27:17.063 : Cap:THERMAL_PROTECTION:1
18:27:17.063 : Cap:MOTION_MODES:1
18:27:17.063 : Cap:ARCS:1
18:27:17.063 : Cap:BABYSTEPPING:1
18:27:17.063 : Cap:CHAMBER_TEMPERATURE:0
18:27:17.063 : Cap:COOLER_TEMPERATURE:0
18:27:17.063 : Cap:MEATPACK:0
18:27:17.063 : Cap:CONFIG_EXPORT:0
18:27:17.063 : area:{full:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}},work:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}}}
18:27:17.063 : X:0.0000 Y:0.0000 Z:0.0000 E:0.0000 Count X:0 Y:0 Z:0
18:27:17.063 : echo:DEBUG:INFO,ERRORS
18:27:17.063 : echo:No media
18:27:17.063 : echo:Unknown command: "M80"
18:28:12.249 : Y driver error detected: 0x801600D0
18:28:12.249 : coil short circuit
18:28:12.249 : X	Y	Z
18:28:12.249 : Address		0	0	0
18:28:12.296 : Enabled		false	true	false
18:28:12.296 : Set current	900	900	900
18:28:12.311 : RMS current	887	887	887
18:28:12.343 : MAX current	1251	1251	1251
18:28:12.343 : Run current	28/31	28/31	28/31
18:28:12.343 : Hold current	22/31	22/31	22/31
18:28:12.358 : CS actual	22/31	22/31	22/31
18:28:12.358 : PWM scale
18:28:12.389 : vsense		1=.18	1=.18	1=.18
18:28:12.405 : stealthChop	false	false	false
18:28:12.436 : msteps		16	16	16
18:28:12.452 : interp		true	true	true
18:28:12.483 : tstep		max	max	max
18:28:12.483 : PWM thresh.
18:28:12.483 : [mm/s]
18:28:12.515 : OT prewarn	false	false	false
18:28:12.515 : triggered
18:28:12.515 : OTP		false	false	false
18:28:12.530 : pwm scale sum	25	25	25
18:28:12.562 : pwm scale auto	0	0	0
18:28:12.577 : pwm offset auto	36	36	36
18:28:12.608 : pwm grad auto	14	14	14
18:28:12.624 : off time	3	3	3
18:28:12.655 : blank time	24	24	24
18:28:12.655 : hysteresis
18:28:12.671 : -end		-1	-1	-1
18:28:12.702 : -start		1	1	1
18:28:12.702 : Stallguard thrs	0	0	0
18:28:12.733 : uStep count	56	696	56
18:28:12.733 : DRVSTATUS	X	Y	Z
18:28:12.749 : sg_result	0	0	0
18:28:12.780 : stst
18:28:12.796 : olb		*	*	*
18:28:12.827 : ola		*	*	*
18:28:12.843 : s2gb
18:28:12.874 : s2ga
18:28:12.889 : otpw
18:28:12.921 : ot
18:28:12.936 : 157C
18:28:12.968 : 150C
18:28:12.999 : 143C
18:28:13.015 : 120C
18:28:13.046 : s2vsa			*
18:28:13.061 : s2vsb
18:28:13.061 : Driver registers:
18:28:13.077 : X	0x80:16:00:C0
18:28:13.077 : Y	0x80:16:00:D0
18:28:13.093 : Z	0x80:16:00:C0
18:28:13.093 : echo:Driver error
18:28:13.131 : Error:Printer halted. kill() called!
18:28:13.132 : //action:poweroff
18:28:53.148 : No start signal detected - forcing start
18:28:56.251 : Testing X connection... OK
18:28:56.251 : Testing Y connection... OK
18:28:56.266 : Testing Z connection... OK
18:28:56.266 : Error:Line Number is not Last Line Number+1, Last Line: 0
18:28:56.266 : Resend: 1
18:28:56.298 : FIRMWARE_NAME:Marlin 515S 2.1.1 (Sep 25 2022 17:41:37) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1CNC 515S EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
18:28:56.298 : Cap:SERIAL_XON_XOFF:0
18:28:56.298 : Cap:BINARY_FILE_TRANSFER:0
18:28:56.298 : Cap:EEPROM:1
18:28:56.298 : Cap:VOLUMETRIC:1
18:28:56.298 : Cap:AUTOREPORT_POS:1
18:28:56.298 : Cap:AUTOREPORT_TEMP:1
18:28:56.298 : Cap:PROGRESS:0
18:28:56.298 : Cap:PRINT_JOB:1
18:28:56.298 : Cap:AUTOLEVEL:0
18:28:56.298 : Cap:RUNOUT:0
18:28:56.298 : Cap:Z_PROBE:0
18:28:56.298 : Cap:LEVELING_DATA:0
18:28:56.298 : Cap:BUILD_PERCENT:0
18:28:56.298 : Cap:SOFTWARE_POWER:0
18:28:56.298 : Cap:TOGGLE_LIGHTS:0
18:28:56.298 : Cap:CASE_LIGHT_BRIGHTNESS:0
18:28:56.298 : Cap:EMERGENCY_PARSER:1
18:28:56.298 : Cap:HOST_ACTION_COMMANDS:1
18:28:56.298 : Cap:PROMPT_SUPPORT:1
18:28:56.298 : Cap:SDCARD:1
18:28:56.298 : Cap:MULTI_VOLUME:0
18:28:56.298 : Cap:REPEAT:0
18:28:56.298 : Cap:SD_WRITE:1
18:28:56.298 : Cap:AUTOREPORT_SD_STATUS:1
18:28:56.298 : Cap:LONG_FILENAME:0
18:28:56.298 : Cap:LFN_WRITE:0
18:28:56.298 : Cap:CUSTOM_FIRMWARE_UPLOAD:0
18:28:56.298 : Cap:EXTENDED_M20:0
18:28:56.298 : Cap:THERMAL_PROTECTION:1
18:28:56.298 : Cap:MOTION_MODES:1
18:28:56.298 : Cap:ARCS:1
18:28:56.298 : Cap:BABYSTEPPING:1
18:28:56.298 : Cap:CHAMBER_TEMPERATURE:0
18:28:56.298 : Cap:COOLER_TEMPERATURE:0
18:28:56.298 : Cap:MEATPACK:0
18:28:56.298 : Cap:CONFIG_EXPORT:0
18:28:56.298 : area:{full:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}},work:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}}}
18:28:56.304 : X:0.0000 Y:0.0000 Z:0.0000 E:0.0000 Count X:0 Y:0 Z:0
18:28:56.304 : echo:DEBUG:INFO,ERRORS
18:28:56.304 : echo:No media
18:28:56.304 : echo:Unknown command: "M80"
18:28:56.306 : echo:DEBUG:INFO,ERRORS
18:29:12.276 : X driver error detected: 0x801600E0
18:29:12.276 : coil short circuit
18:29:12.276 : X	Y	Z
18:29:12.276 : Address		0	0	0
18:29:12.307 : Enabled		true	false	false
18:29:12.307 : Set current	900	900	900
18:29:12.339 : RMS current	887	887	887
18:29:12.354 : MAX current	1251	1251	1251
18:29:12.354 : Run current	28/31	28/31	28/31
18:29:12.354 : Hold current	22/31	22/31	22/31
18:29:12.385 : CS actual	22/31	22/31	22/31
18:29:12.385 : PWM scale
18:29:12.401 : vsense		1=.18	1=.18	1=.18
18:29:12.432 : stealthChop	false	false	false
18:29:12.464 : msteps		16	16	16
18:29:12.479 : interp		true	true	true
18:29:12.510 : tstep		max	max	max
18:29:12.510 : PWM thresh.
18:29:12.510 : [mm/s]
18:29:12.526 : OT prewarn	false	false	false
18:29:12.526 : triggered
18:29:12.526 : OTP		false	false	false
18:29:12.557 : pwm scale sum	25	25	25
18:29:12.573 : pwm scale auto	0	0	0
18:29:12.604 : pwm offset auto	36	36	36
18:29:12.632 : pwm grad auto	14	14	14
18:29:12.651 : off time	3	3	3
18:29:12.682 : blank time	24	24	24
18:29:12.682 : hysteresis
18:29:12.714 : -end		-1	-1	-1
18:29:12.729 : -start		1	1	1
18:29:12.729 : Stallguard thrs	0	0	0
18:29:12.761 : uStep count	472	728	88
18:29:12.761 : DRVSTATUS	X	Y	Z
18:29:12.776 : sg_result	0	0	0
18:29:12.807 : stst
18:29:12.839 : olb		*	*	*
18:29:12.854 : ola		*	*	*
18:29:12.886 : s2gb
18:29:12.901 : s2ga
18:29:12.932 : otpw
18:29:12.948 : ot
18:29:12.979 : 157C
18:29:12.995 : 150C
18:29:13.026 : 143C
18:29:13.042 : 120C
18:29:13.073 : s2vsa
18:29:13.089 : s2vsb		*
18:29:13.089 : Driver registers:
18:29:13.104 : X	0x80:16:00:E0
18:29:13.104 : Y	0x80:16:00:C0
18:29:13.120 : Z	0x80:16:00:C0
18:29:13.120 : echo:Driver error
18:29:13.163 : Error:Printer halted. kill() called!
18:29:13.163 : //action:poweroff
18:30:01.726 : Communication timeout - reset send buffer block
18:54:27.130 : No start signal detected - forcing start
18:54:28.920 : Testing X connection... OK
18:54:28.936 : Testing Y connection... OK
18:54:28.951 : Testing Z connection... OK
18:54:30.217 : Error:Line Number is not Last Line Number+1, Last Line: 0
18:54:30.217 : Resend: 1
18:54:30.233 : FIRMWARE_NAME:Marlin 515S 2.1.1 (Sep 25 2022 17:41:37) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1CNC 515S EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
18:54:30.233 : Cap:SERIAL_XON_XOFF:0
18:54:30.233 : Cap:BINARY_FILE_TRANSFER:0
18:54:30.233 : Cap:EEPROM:1
18:54:30.233 : Cap:VOLUMETRIC:1
18:54:30.233 : Cap:AUTOREPORT_POS:1
18:54:30.233 : Cap:AUTOREPORT_TEMP:1
18:54:30.233 : Cap:PROGRESS:0
18:54:30.233 : Cap:PRINT_JOB:1
18:54:30.233 : Cap:AUTOLEVEL:0
18:54:30.233 : Cap:RUNOUT:0
18:54:30.233 : Cap:Z_PROBE:0
18:54:30.233 : Cap:LEVELING_DATA:0
18:54:30.233 : Cap:BUILD_PERCENT:0
18:54:30.233 : Cap:SOFTWARE_POWER:0
18:54:30.233 : Cap:TOGGLE_LIGHTS:0
18:54:30.233 : Cap:CASE_LIGHT_BRIGHTNESS:0
18:54:30.233 : Cap:EMERGENCY_PARSER:1
18:54:30.233 : Cap:HOST_ACTION_COMMANDS:1
18:54:30.233 : Cap:PROMPT_SUPPORT:1
18:54:30.233 : Cap:SDCARD:1
18:54:30.233 : Cap:MULTI_VOLUME:0
18:54:30.233 : Cap:REPEAT:0
18:54:30.233 : Cap:SD_WRITE:1
18:54:30.233 : Cap:AUTOREPORT_SD_STATUS:1
18:54:30.233 : Cap:LONG_FILENAME:0
18:54:30.233 : Cap:LFN_WRITE:0
18:54:30.233 : Cap:CUSTOM_FIRMWARE_UPLOAD:0
18:54:30.233 : Cap:EXTENDED_M20:0
18:54:30.233 : Cap:THERMAL_PROTECTION:1
18:54:30.233 : Cap:MOTION_MODES:1
18:54:30.233 : Cap:ARCS:1
18:54:30.233 : Cap:BABYSTEPPING:1
18:54:30.233 : Cap:CHAMBER_TEMPERATURE:0
18:54:30.233 : Cap:COOLER_TEMPERATURE:0
18:54:30.233 : Cap:MEATPACK:0
18:54:30.233 : Cap:CONFIG_EXPORT:0
18:54:30.233 : area:{full:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}},work:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}}}
18:54:30.241 : X:0.0000 Y:0.0000 Z:0.0000 E:0.0000 Count X:0 Y:0 Z:0
18:54:30.241 : echo:DEBUG:INFO,ERRORS
18:54:30.241 : echo:No media
18:54:30.241 : echo:Unknown command: "M80"
18:54:30.242 : echo:DEBUG:INFO,ERRORS
18:54:46.950 : X driver error detected: 0x801600E0
18:54:46.950 : coil short circuit
18:54:46.950 : X	Y	Z
18:54:46.966 : Address		0	0	0
18:54:46.997 : Enabled		true	false	false
18:54:46.997 : Set current	900	900	900
18:54:47.013 : RMS current	887	887	887
18:54:47.044 : MAX current	1251	1251	1251
18:54:47.044 : Run current	28/31	28/31	28/31
18:54:47.044 : Hold current	22/31	22/31	22/31
18:54:47.060 : CS actual	22/31	22/31	22/31
18:54:47.060 : PWM scale
18:54:47.091 : vsense		1=.18	1=.18	1=.18
18:54:47.106 : stealthChop	false	false	false
18:54:47.138 : msteps		16	16	16
18:54:47.153 : interp		true	true	true
18:54:47.185 : tstep		max	max	max
18:54:47.185 : PWM thresh.
18:54:47.185 : [mm/s]
18:54:47.216 : OT prewarn	false	false	false
18:54:47.216 : triggered
18:54:47.216 : OTP		false	false	false
18:54:47.231 : pwm scale sum	25	25	25
18:54:47.263 : pwm scale auto	0	0	0
18:54:47.278 : pwm offset auto	36	36	36
18:54:47.310 : pwm grad auto	14	14	14
18:54:47.325 : off time	3	3	3
18:54:47.356 : blank time	24	24	24
18:54:47.356 : hysteresis
18:54:47.372 : -end		-1	-1	-1
18:54:47.403 : -start		1	1	1
18:54:47.403 : Stallguard thrs	0	0	0
18:54:47.435 : uStep count	440	56	56
18:54:47.435 : DRVSTATUS	X	Y	Z
18:54:47.450 : sg_result	0	0	0
18:54:47.481 : stst
18:54:47.497 : olb		*	*	*
18:54:47.528 : ola		*	*	*
18:54:47.544 : s2gb
18:54:47.575 : s2ga
18:54:47.591 : otpw
18:54:47.622 : ot
18:54:47.638 : 157C
18:54:47.669 : 150C
18:54:47.685 : 143C
18:54:47.716 : 120C
18:54:47.731 : s2vsa
18:54:47.763 : s2vsb		*
18:54:47.763 : Driver registers:
18:54:47.778 : X	0x80:16:00:E0
18:54:47.778 : Y	0x80:16:00:C0
18:54:47.794 : Z	0x80:16:00:C0
18:54:47.794 : echo:Driver error
18:54:47.829 : Error:Printer halted. kill() called!
I see 2 things that came before the Marlin halted… unknown M80, and X driver error:
18:00:20.759 : echo:Unknown command: “M80”
Open loop warnings on all coils here, as well as what appears to be a low side short on the Xb coil.
18:54:47.544 : s2gb
18:54:47.575 : s2ga
18:54:47.591 : otpw
18:54:47.622 : ot
18:54:47.638 : 157C
18:54:47.669 : 150C
18:54:47.685 : 143C
18:54:47.716 : 120C
I would give all the motor connections and wires a once over.
It also says coil short circuit a few times. I think this is s2vsb.
Thanks for the help.
I checked my power and motor inputs both 24.3V. Verified power inlet is not shorted. Checked fuses none blown and seem well connected. Stepper connections appear tight. Replaced the driver jumpers. Swapped my extra driver to the other positions. Manually jogged after each change to check and received the same error.
Is there a way I can check where the short circuit is coming from, what is/ where is the Xb Coil? Does the M80 error mean the board doesn’t know what to do with that command?
Do you have a software-switchable power supply? M80 turns that on, but I believe it needs to be enabled in the firmware. I’ve only ever seen that when using a PC power supply that supplies 5v standby to run the logic power but needs the 12V rails turned on for the heaters and motors.
This is what I am using.
M80 is a red herring.
The wiring issues reported in your log are between the TMC driver and the motor. It may be a short in the stepper cable, a short in the stepper itself, or a short in the skr board.
In the picture, it is just sitting on a table. Make sure there isn’t anything shorting the pins on the underside of that board. Look closely for any poor solder joints there too.
Given the screen pic of your power supply, it won’t be software switchable, so (when you’ve got your other issue sorted out) I’d check your Start gcode areas for the M80 command and remove it or comment it out. Low priority in the face of your other issue.
Interesting. I gave the board a good inspection with a magnifying glass and didn’t notice any poor soldering. Continued the flopping around of the driver and motors to see if I have a combination that worked didn’t find one. Probably a silly question but does the board know when the motors are connected, don’t get an error if I try to move an axis with no stepper connected. Anything else I should test or maybe the board is a dud?
I had the same error it turned out that my motor had a another coil configuration - try to switch the two wires in the middle.
Thanks so much for letting me know this solved the issue motor spins as it should now!!!
