What holds the vinyl cutter holder?
I recently purchased the vinyl cutter from the V1 Engineering shop. The page links to a vinyl cutter holder here https://www.thingiverse.com/thing:1860310 which I have printed. My question is what does the vinyl holder attach to? It does not attach directly to the Z rails. At first I thought it was a blank tool mount, but the blank tool mount in github lacks the required holes.
Thanks.
It is the burly tool mount.
This is the primo: https://www.thingiverse.com/thing:4569385
Ah ok. And then this attaches to the lower tool mount.
Got it. Thanks!
Rob,
And “upside-down” from the way you might expect, just looking at the part. It had me puzzled for a bit. The large flange on the circular portion of the mount is the bottom.
Oops, the last one listed above is for a direct connection to the z-rails.
Here’s another on that just slips into the Dewalt lower mount, with the flange on the bottom:
Mike
This one from the V1 store:
This bolts to the Z tubes, then you zip-tie the drag knife to this.
