I wanted to make something new and interesting to look at in the coffee shop and landed on this…
It seemed like the Polargraph addition to the Wall Mounted Pen Plotter was lost on most people, and it was also hard to figure out what to draw with it. The original system with the linear rail mounted pen carriage is capable of much more intricate plots, but it can’t be used at the same time as the Polargraph, which was intended to be more interesting to watch and not so much about the result, so I decided to move the Polargraph out of the existing frame and locate it on the opposite wall. Since the pen hangs on strings and the lift mechanism is remote controlled via an RF signal, I kept the V1 Jackpot controller and associated electronics where it is and routed the strings up the wall, across the ceiling and down the opposite wall via a pulley system. All I needed to do was to make a new drawing “canvas” and modify the geometry settings in FluidNC based on the size of the new canvas. Easy. ![]()
Still in the prototype phase but gaining on it. Here is what I have so far…
Rather than use the existing motors, I added two new ones (still two slots left on the Jackpot) and mounted them in the upper left of the frame.
The strings are routed over to the new canvas on the opposite wall, which is currently pretty ugly, but I am working on that. The plan is to mount the pulley (4 sheaves) on a piece of live edge Cuban Mahogany and use a piece of tempered glass for the drawing surface (instead of that MDF you see in the pic). So, no 3d printed plastic and no MDF. Just beautiful wood.
The 3d printed gondola was also pretty ugly, so I am replicating it out of wood. Still figuring out the weight and balance and the pen lift mechanism. Those washers are currently needed for weight but will eventually go away and the pen lift circuit, battery, and servo will be hidden in the wood box on the bottom of the gondola. The pen is suspended on .8mm brass rods and is held to the paper via gravity acting on the weight of the pen. It’s a bit temperamental but sorta works.
So, in this configuration, the two can be drawing at the same time. Like in these pics, the main machine is drawing one of Picasso’s works (Girl with Mandolin) while the new Polargraph, across the room, is drawing Picasso himself.
More to follow…
