Not another MP3DP V4
The HDMI5/7 is as well. Just not the one that can mount the Pi to the back like the Pi TFT50/70
I have the HDMI5 on my E5+ and the HDMI7 on the V4. Both running klipper screen. It works real nice!
Oh. It’s a 10" and I’m using it with a pi.
ELECROW 10.1 Inch Touchscreen Monitor Compatible with Raspberry Pi Screen 1920X1080p IPS Monitor VGA HD Display for Laptop Jetson Nano Win PC (Touch Sceen Version) https://a.co/d/fW6yRcv
As long as its HDMI connected to the pi you are running klipper on and a usb connection for the touch screen that will run Klipper Screen no problem. And at 10" you’ll be able to see it across the room LOL
I’m not using klipper. I’m using it with octoprint.
Ahh ok. Misunderstood. I’ve never used that but still should be a sweet setup!
10", goodness how big is your printer. I did not expect it to be 10" NICE!
Print volume is 300 cubed.
It’s a little humid in the shop today.
Well….if it makes you feel any better….
I believe it. Im 2 hrs from you and its been storming off and on all day
I guess I will need to get something for my garage now.
I’d suggest Accuweather probes. They’re amazing.
I wanted the little dial inside my printer just to see if the printer ran different than the rest of the shop with the heaters running.
There have been a few projects where people have read the cheap weatherstation RF using SDR. They can then add them to home assistant or whatever. I use BLE sensors (Xiaomi ones) and Esphome as a BLE interface.
Nice. I have a full blown weather station, so I just use their remote sensors. I can have up to 8 of them. I think I’m currently running 4. It all flows up to their site and then I have Home Assistant pulling the data back down for automation.
I use the SDR linked below for a variety of things, and was using one to read a home weather station until the weather station got wacky (and was then killed off by 100Mph winds)
https://www.amazon.com/Nooelec-RTL-SDR-SDR-100kHz-1-75GHz-Enclosure/dp/B01HA642SW/ref=sr_1_1?dib=eyJ2IjoiMSJ9.uI_frCr_pkd1oUJU8qqF99r6sxoY-3Ynk7fF5j8iJFw8r7k7Qfqj7k9DZv-Z0fa6tAxqstn9Br7f_cdwrHeslx9P0kVpMFW9xosUwHM8hf9w8dFGm6_DexSsXigEKDLMPzpMe_Zy5Ama3aCuacWZR_b0BZw4MvhOTXO34uAfJ_AG_5xmxTzumi-PgUzCy9bbZLh-H42vCTZnUAYiCBBPLtGrUbRIaG-idHMF9pWWM0w.90qy5164v3r9avsm2dRnekDBpr0qUsO_tj-PseFemYg&dib_tag=se&keywords=nooelec&qid=1709687816&sr=8-1
It has a really good TCXO for a $34 SDR reciever. I use them for ham radio stuff, ADS-B recievers, had one reading TPMS, etc.
Great. Now I have to go see if I can get one of those to work with the AccuWeather stuff.
Oh… And did you say ADS-B?
I have a full blown weather station outside as well. And enough AHT20 sensors around to drown in temp/humidity data LOL. They are just so cheap that I end up throwing them on everything LOL. My weather station does great for everything but wind. Its too blocked where its at. But a friend of mine gave me an old 40’ ham radio tower to set up and put it on top. If I ever get around to setting that up I’ll have great wind data as well LOL
I finally have an ASA core printed. Ignore the horrible z wobble.
I’ll try to get it installed this weekend.
Got the core installed. Also printed a fan mount in ASA. Need to tune the mucrostep again for the first layer, then it’ll be printing again.
Awesome! Looking good!
