Hello
I cant find the files for the flat aluminum parts , I don’t have fusion 360 so is there just the dxf files. I
built the LR3 and can mill my own parts like cutting the struts, which had the dxf files on V1 Engineering
site. Am I just missing them some how. but when I click on the link it sends me to a markup page for fusion 360 and tries to get me to download 360. I don’t use windows so it just isn’t happening.
If using standard build size, the flat parts dxf files can be found on Printables
awesome thanks
you wouldn’t happen to know how big of a piece of aluminum I would need to mill all the parts. It tells us the thickness on V1 site, but not sq. inches/mm
I used only one of these plates Ryan has linked in his build thread, with a bit to spare.
1 is fine if you do your layout tight, and don’t make any mistakes.
You can see how I laid mine out to fit in my build thread
And if you happen to need help with milling the aluminum, I outlined my process that made it pretty easy in this thread
Here is how much I had left of that sheet when done:
Thanks, I must of gone off reading all those links and never thanked you. much appreciated
