MP3DP CoreXY serial number log V3-V4
Tony, was your file something sharable like an Inkscape file, or should I try my hand at something?
I think I did part in fusion and part in inkscape. I’ll doctor it up and share it.
hmmmm…milled aluminum plate sounds nice and fancy… And I have some aluminum that’s not the right size for anything I need anyways LOL
Here we go. SVG and Fusion Archive. The text is Impact, so if you don’t have it installed you’ll want to get it. I included my Fusion setup, but of course, you’ll want to make sure it does what you want. I didn’t actually use that one, I used a copy of it and haven’t done anything to proof THIS copy.
Repeat Tag.zip (368.7 KB)
So this…
or this…
First one
Here is number 12!
300x300x350
E3D Hemera hotend
SKR Pro v1.2 with 2209 drivers
750W AC heated bed 1/4" aluminum plate with magnetic build plate
Project Started April 4, 2023
First Print May 12, 2023
IMG_0822
I was going to set mine up as a test run in some acrylic before I cut my big panels out for the printer. It seems that the logo got messed up somewhere between Fusion and Estlcam. Should I try to reimport the logo into fusion and resave the DXF or should I try and just insert it into estlcam and place it there?
Probably easier to insert into estlcam and combine it there, Logo Files – V1 Engineering Inc
I tried that but couldn’t get just the one logo. they all had to move together and it got too complicated lol. So I reopened it in fusion and it looked great. After the 4th time I messed around and saved it again it came over perfect. IDK what the issue was but I got it now. Thanks!
Okay then, if you’re just giving away serial numbers, I’m rocking… :metal: 13 :metal:
My MP3DP v4 Repeat Voron Λ.ʌ.ron flavored build journey.
Usable : 250x250x250
Software: MainSail OS, Klipper. Used Kaiuh, so have Octoprint and Fluidd too. 3.5" resistive touch display for Pi, runs KlipperScreen.
Controller : BTT Octopus v1.1, Pi4
CanBus-Expansion : BTT EBB36-v1.2 (includes ADXL345)
Extruder-HotEnd : BIQU H2 V2S Revo Extruder
Probe : ANTCLABS BLTouch v3.1
Frame : Alu Extrusion, Polycarbonate, sheet metal and plywood panels.
Heated Bed: 120V 500W Heated Bed
Started: Idea first seeded Aug '22 when printing beta Swiss Z post. Started building ~23-03-13.
Finished: When I am.
Update: Less turdy 100mm calibration crown print… This was with PEI curled up since I haven’t bothered to stick down magnet layer yet, hence the floater… Was mistakenly using bowden retraction settings and other Ender settings. I need to create a separate printer profile…
100mm-crown.zip (171.1 KB)
CLAIMED!!
MP3DP v4 ser 000014
300x300x390 print area
310x320 mm bed, 24 V heated
smooth pei print surface with magnetic release
BQ H2V2s direct drive extruder
BQ Octopus controller
Klipper/mainsail firmware running on
Rpi 3B+ with 7" touch screen
Powered by tobsun 24 V to 5v 10A converter
24V 18A power supply
5 nema 17s from v1E.com
Bltouch
45 degree part cooling fan
Old school analog controls
3 point bed leveling
Orange and black parts are abs prints. White is pla.
How did the benchy turn out?
It has been a year since I built my first MP3DP V4 and I realize I never registered it with a Serial #!
Introducing MP3DP V4 Serial # 000015
I have my second MP3DP V4 in the works now. Just need to finish up the wiring and get the bed installed and it should be ready to go. It’s just hard to find the time to work on it!
Introducing MP3DP V4 Serial # 000016
