Minnetonka, Minnesota Primo Build
I’d just add it to the ESP. :slight_smile:
will a 4.7k 1/2 watt resistor work?
If I were you, I’d solder that resistor on the ESP-32 and be back up and running.
(And, I do have an early white Jackpot board, and it has a resistor soldered on its’ ESP-32 :slight_smile: )
I see I"m not alone. :smile:
I’m a bit weird that I usually decide I need spares for electronics. In my own case, I have a JL-1 laser, a pair of LR4 beta builds, and a testbed / bench test jackpot. All have jackpots.
The testbed is the one with the white board. I have a generic, authentic, and USB-C variant of ESP-32 each of which has the resistor on them. The modded ESP-32s all work fine in all the boards I have.
Yes, It has a much bigger body from the power rating than what you need, but it will work just fine.
well I’m off to my local electronics surplus store to get that resistor… I’ll move the wires to give the wifi chip its personal space install the resistor on the esp32 and report back. Fingers crossed.
4.7K nominal, but any value 1K to 4.7K would work for you.
Nice I don’t even need to leave the house: I found these 4.7k 1/2 w resistors in an old arduino cnc project stash:
If I’m interpreting the color coding correct they are 4.7k 1/2 watt:
OK, I’ve joined the resistance now: wish me luck.
no bueno…
stillhas the tmc driver errors:
$G
$SS
[MSG:INFO: FluidNC v3.9.1 https://github.com/bdring/FluidNC]
[MSG:INFO: Machine MPCNC]
[MSG:INFO: UART2 Tx:gpio.14 Rx:gpio.13 RTS:NO_PIN Baud:1000000]
[MSG:INFO: uart_channel2 created at report interval: 75]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (3.000,1223.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:0 CS:NO_PIN Step:I2SO.2 Dir:I2SO.1 Disable:I2SO.0 R:0.110]
[MSG:INFO:  X Neg Limit gpio.25]
[MSG:INFO:   Motor1]
[MSG:INFO:     tmc_2209 UART1 Addr:3 CS:I2SO.14 Step:I2SO.13 Dir:I2SO.12 Disable:I2SO.15 R:0.110]
[MSG:INFO:  X2 Neg Limit gpio.35]
[MSG:INFO: Axis Y (3.000,2443.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:1 CS:NO_PIN Step:I2SO.5 Dir:I2SO.4 Disable:I2SO.7 R:0.110]
[MSG:INFO:  Y Neg Limit gpio.33]
[MSG:INFO:   Motor1]
[MSG:INFO:     tmc_2209 UART1 Addr:3 CS:I2SO.19 Step:I2SO.18 Dir:I2SO.17 Disable:I2SO.16 R:0.110]
[MSG:INFO:  Y2 Neg Limit gpio.34]
[MSG:INFO: Axis Z (-100.000,200.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:2 CS:NO_PIN Step:I2SO.10 Dir:I2SO.9 Disable:I2SO.8 R:0.110]
[MSG:INFO:  Z Neg Limit gpio.32:low]
[MSG:ERR: X Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: X2 Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: Y Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: Y2 Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: Z Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Probe gpio.36:low]
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Pn:Z|WCO:0.000,0.000,0.000>
Send Command...
What happens if you disconnect the USB cable, then power cycle the Jackpot?
This is what it looks like when the ESP32 isn’t plugged into the Jackpot. So, if you powered the USB first, then the Jackpot, it might have the same result.
Also, I’d try running it from http://192.168.0.1 in the browser. I know that captive portal stuff can cause some grief.
Interesting. Let me think about next steps. It looks like you have the ESP-32 pullup resistor installed correctly
Is it me, or do all the wire colors look different between these photos:
Edit- in the lower photo, the VMOT power wiring looks to be fairly small AWG.
Can I get a close-up of the VMOT wire connector and the stepper just above and to the right of that?
Edit2- those are two different builds. One has red heat sinks, one has blue heat sinks.
The wiring is indeed different between the two.
Are you having issues with two different builds?
disconnecting the usb cable worked:
Dropboxworking sort of
Good call @jeyeager .
The reason is that the USB cable powers up the ESP-32, but only the ESP-32. So the rest of thes system ‘isn’t there’ electrically when the system boots.
Jackpot has to be powered on before USB is connected for it to work right.
Let’s see a $SS and some motion.
NOTE: That VMOT wiring is probably on the small side as noted.
Pro tip: just use your multimeter when you only need to know the resistance of one resistor. It can’t make a math mistake.
:tada:
Jim
its just one build I think the photos are just getting colors mixed up between converting file format from heic to jpg
I can change the red and black +/_ 24 v input wired to larger awg
the stepper 4pin dupont connectors that I made were crap so I spliced in the 4 pin dupont connectors from V1… wiring is definitely my weak point.
Looks like you have a great build well underway.
I’ve seen far worse wiring.
I’d say you have a good handle on buiilding a clean system.
Got interrupted by a prospective client call. gotta pay for those hobbies now don’t we.
Some retrospective- some folks like Jason did have early Jackpots and never have an issue. Adding the pull-up resistor doesn’t hurt and that ESP-32 you modified will work in any Jackpot, and even in most any other application.
It is possible if you were hooking up a PC over USB then powering on the machine that your motion issues were because of that. We can’t tell the difference between the two scenarios as the symptom is the same either way. For an ESP-32 that needs the pullup, it will boot intermittently. For a Jackpot that had the ESP-32 powered up over USB then the Jackpot powered on, the system will never run right.
If the jackpot were powered up first, then the USB can be connected and disconnected at will and there won’t be problems as long as the Jackpot stays on. At that point, the jackpot has to be turned on before USB.
This is just another of the reasons that running the machine over USB isn’t recommended.
Either way, I’m looking forward to seeing more of your progress with your build.
  1. adding the 4k resistor now lets the Jackpot boot consistently without driver errors (that’s progress)
  2. as long as the jackpot boots correctly I can home and jog etc. It’s working at that point
  3. the FluidNC Dial is spotty sometimes it says NC (not connected) after booting the jackpot, sometimes it shows Idle but the touch screen is not functioning (basically useless at that point because some functions require a screen swipe) and sometimes it fires up just fine and works properly. It’s not reliable so I’ll use it if it’s working but set it aside if it’s not.
  4. As long as I follow a boot sequence where the jackpot boots before connecting the USB that seems like a repeatable and reliable workflow
  5. the wifi connection is also spotty the cheap minipc I have may not have a very good wifi chip and the esp32 wifi seems to also not be that robust. I’ll use wifi sparingly to upload files to the SD card ONLY and to check with FluidNC webUI if the jackpot is up and running.
  6. once the jackpot is up and running I can use UGS or G-Sender to load and send G-code jobs over USB.
  7. I’m also going to try out the upload of files to the SD card and get familiar with that workflow too.
is there any user interface (similar to UGS) that gives you a visual representation of the g-code and shows the tool head location as it runs through the g-code? As a visual person, this is what I miss about the Fluidnc Web UI.
for now, though I think I’m 90% confident I can run the machine and make some sawdust.
thanks again everyone I would never have gotten this far by myself.
