LR4 Aluminum Sheet Milling (e.g. ~28 gauge / 0.02" / 0.5mm)
Curious how LR4 owners are milling ~28-gauge (0.02" / ~0.5 mm) aluminum sheets?
Thinking something like 8mm/s (~19ipm), 1mm DOC, 1/8" single O-flute, ~10k rpm, NOT trochoidal, air mist, double sided xfasten (wood working tape) and a few well placed screws to hold down. Goal being to prevent flapping and bit catching and snagging.
Posting here given price of bits/stock, and delivery times for replacement parts. Also, betting someone(s) here will have some neat tips and results to share.
Currently cutting contours/holes/notches for baffles in basement joist bays exposed to adjacent crawlspace. Can’t do regular 2"x12"x14-1/2" blocking because of HVAC/plumbing/electrical running through. Am making tight fit to block active mice/insects problem. Using 1/4" gap or 1/8" gap hardware mesh for most bays. Will rely on foam to air seal for fire-safety and insulation codes. Intentionally over designing for couple of complicated bays as practice run before milling panels for other projects.
Saw some nice info and examples in recent LR4 Alu milling topics focused on 1/4" and thicker stock…
0.020" thickness won’t provide a lot of challenges IMO. Biggest issue might be chip welding. An IPA air mist should take care of that, along with suitable feeds.
8mm/s (480mm/min) seems kind of slow, if you want to maintain a recommended chip load.
Using a suggested CL of 0.003-0.004 ipt (0.076-0.102 mm/tooth), a single tooth mill and a speed of 10000, you would want a theoretical feed rate (FR=CL * RPM) of (0.076 - 0.102)*10000 = (760 - 1000) mm/min (12.7 - 16.7 mm/s)
Going too slow might be worse for the mill than going too fast, especially with such a thin stock.
But a few test cuts would tell you pretty quick what works best.
No, trochoidal isn’t needed here, especially given the thin stock
This is likely to be your biggest challenge IMO. The stock is so thin, the upcut mill will lift it if it is not secured every 4-6". Not sure how well the double sided tape will work, or if it will just gum up the mill. I had some green painters tape on a piece of aluminum, and it completely messed up the mill.
