Hi everyone!
I’m considering building a LowRider 4 as a hobby project and have a few questions before getting started.
1. Is LowRider 4 suitable for a complete beginner?
I have no previous CNC experience, but I do have experience with 3D printing and using various tools for DIY projects and home repairs. However, I have no experience with electronics, soldering, or programming.
Is this a realistic project for someone like me? How difficult is the electronics and software setup?
2. Can I build a small, portable LowRider 4?
I don’t have a workshop or a permanent indoor space for the machine. I’m considering a smaller build, with a working area of around 500 × 500 mm, that I could store indoors and move outside whenever I want to use it.
Is this practical? Would moving the machine frequently cause alignment or calibration problems? Would you recommend a different CNC design for this kind of use?
3. Where should I buy the parts in Europe?
I live in the EU and plan to 3D print all the printed parts myself. Since the European kits don’t seem to be available at the moment, I assume I’ll need to source the remaining components individually.
Are Amazon de and AliExpress good options, or are there better EU suppliers?
Are there any specific brands or sellers you recommend or would avoid?
Which components are worth spending more on, and where is it safe to save money?
4. What materials can I realistically work with?
My main goal is to learn CNC machining and work primarily with wood, plywood, and plastics. However, I’d also like to experiment with milling aluminum occasionally.
Is the LowRider 4 capable of machining aluminum with reasonable results, especially in a smaller 500 × 500 mm configuration? I understand it would require slower speeds and lighter cuts.
5. Any other advice?
I’m not planning to use the machine commercially.
Are there any common beginner mistakes, unexpected costs, or things you wish you had known before your first build?
Thanks in advance for any advice! I’d really appreciate hearing from people who have already built and used a LowRider 4.
