LowRider 3 — Aza's IDEX upgrade (2 Routers!)
Assembly > Core > Kobalt Router Semi-clear Vac Hose mount
Hoping to increase light on stock/bit by modifying Printables > V1E > Kobalt Router LR3 Mount.
Printing mix of transparent and Kobalt blue PLA… Swapping filament after printing bottom 3mm.
  • Am using Cura’s “Z Offset Setting” Marketplace plugin to help configure the filament color swap. See Chep’s YT video for details.
Blocked bottom…
Clear bottom…
Learnings
  • Problem: Z Homing may collide with partially printed base parts… fix: Configure initial Z homing to use an extreme XY corner. Rely on subsequent Z-Tilt to true level up the print bed.
  • Remember to disable skirt/brim for upper slices.
Will edit this post and share files when done. Need to see how well the Clear SunLu PLA and SliceWorx Royal Blue PLA bond…
Edit: For this situation, looks like change filament at layer height would be more straightforward than using the z-offset plugin.
