Klipper Help V5
Not a bad idea. Either that or try a new board. But that sucks so hopefully it’s something else. But it’s not making sense at all.
Did you try it with the sensor type set to the generic one? The EPCOS 100K B57560G104F
Edit: that shouldn’t matter…. The one you have is on the list already and you verified it’s the correct one
tried again, nothing.
Powering all the way down and rebooting just to make sure.
Are you sure you picked the right options when using make menuconfig? If you selected the wrong option in there kipper might think you have different pins for something. I would think you wouldn’t have gotten this far but who knows lol. I’m grasping at straws
Worth a shot. I can try that again before swapping the board out.
Why does yours say _stm32f207xx here?
If you look at my config I left the serial for all 3 boards and all of mine say stm32f407. Is your board running a different chip???
Screenshot 2024-02-25 161956
Shiiiiiiiiiite
Might be it right there. If so that’s awesome you found it before swapping boards lol
Make sure you run make clean before you run make
Thank goodness that mess down at the power section would not have been fun.
I learned a lot, you guys are rad, thank you. Should have it flashed in a couple more minutes.
I damn sure hope it works this time lol.
I would never have thought of that. I would have also flashed the exact same bin file on the new board…I had already renamed it…
And I was going to suggest doing that if you had swapped. But then something said let me ask this anyways. That was before I ever noticed the serial being wrong
BINGO!!! in business
The address changed slightly took a second to swap it. Lets see if it will move
Good call!
Right, what a save!
okay it moves but I need endstops and get the directions right.
THANK you thank you thank you!!!Q!
i was messing with one of the esp32’s you sold me and the config.yaml is a lot like messing with the klipper configs… change the file, reload. not bad once you get it going. I really like the touch screen interface on it though.
More like good guess lol
AWESOME! Yeah we need a video asap no matter how short lol. I gotta see this awesome belt setup!
Just realized I never made a Y Endstop bracket…Dang it.
I trigger a home and run over and pop off jumpers on the endstop pins. :rofl: Klipper is too smart. It needs a double tap…
