Jackpot unboxed Easy setup except Y2 won’t turn
Replacement board is connected. All motors run. Thank you!
I need to dig into the config file. Z moves manually but doesn’t home. I’m guessing it’s a software choice. I was wondering how I’d use homing and the probe anyway.
Also I’ll dig into how to use it on my home network instead of having it host its own tiny network. It would be nice to finish a cam file , send it to the jackpot and then run it.
Do this last please. Once you connect, our ability to help goes to nearly zero.
Do your endstops function? Wired correctly. Normally this means it thinks they are triggered and only moves away,
My z endstop is the bit and touch plate. I can see it working by the LED light. It’s normally open unlike the x and y switches. I had seen the tip in the forum and I tried reversing the probe wires. Same result either way. I don’t see the z motor twitch when I home it but it does move correctly on manual commands.
That wont work to home like we do on the LR3. That one homes to X max with endstops. with there being no endstop for Z on the Primo home does nothing. Ryan just fixed that recently. before it would try to home and just drive the Z right out of the core, and yes im speaking from experiance LOL. You can use the probe with ryans start gcode if your using estlcam, or there is also a probe panel you can use as well.
