Did you buy everything from here? - YES
a)If you didn’t or changed some things please don’t leave out any details and include what firmware you flashed.
Are you using end stops? - NO
a)If so please disconnect them.
Someone that can explain why it’s doing that?
If I remove the belts, it moves soooo easy.
But now if I run code, it moves like step by step, not smooth.
And it makes a strange sound… that you can hear.
It almost sounds like it’s trying to turn, but doesnt have power enough on Z-axis.
Not sure what i can do more to make it slide - tension-bolts (the 4) are set kinda loose!
What are you doing? Are you running my test code? From the LCD or Repetier? I followed the instructions according to this link: https://www.v1engineering.com/estlcam-basics/
I do not have the LCD, i’m using Repetier. If i manually jog it, it still does the same like short movements.
Can you control it manually from the lcd or repetier? I can control it from the Repetier with the manual movement, but it stil is stiff like that, in all directions. It’s not smooth at all when i run some code or jog it.
I just removed ALL the belts from the cogs.
I ran the script.
Nothing happens barely, they do a few turns, then nothing.
They just make sounds and its like they have no Power at all…
Ryan, is the Power-indicator supposed to pulsate…? The green light on the Kastar
I just noticed that the green light pulsates at the SAME rate as the motors try to turn.
As i pulled the power coord, it started to pulsate more slowly, and so did the motors.
If you have another power supply 12v 2A or greater you can try that, and if it is the problem I can send you a new supply. Or you can send back the ramps and the power supply and I can test them both and replace the faulty one. I really doubt it is the ramps though since it gets pretty thoroughly tested before shipping. I stopped testing all the power supplies because the 6A have not had any issues.
