How to arrange all parts to cut from single 8x4 sheet
Hi all,
I am using Fusion 360 for my modelling. I am now trying my hand at modelling some cabinets. I want to be able to automatically arrange all the parts to fit onto a single, or the least amount of, 8x4 plywood sheets.
I see that the paid version of Fusion has an auto arrange function. But I am not forking out that kind of money for it.
I came across the MapBoards Pro add-in for Fusion and it does not look too bad but I am looking for some recommendations please.
What software / apps / Fusion add-ins do you all use.
Export each as a separate dxf and use https://deepnest.io/
MapBoards Pro is well worth it if using Fusion 360.
I can second deepest, it’s brilliant. I just import the drawing with all the parts at once, no single exports. Then you add a sheet with its size and say how many you’ve got and it starts arranging.
I do most of my cnc cad with Vectric Aspire, it has an inbuilt nestting option that gives you options for: clearance to borders, the bit size you plan to use and may others (you can make multiple copies to fill a sheet or multiple sheets).
