Oh, I thought they were wired in a way that if the endstops stopped working the machine would not run.
Crud, I just realized the error of my ways. It just will not home if wired wrong, it will still move. Sorry, I will stop interrupting and sit back and read.
I removed the plastic now i think all moters come on but none move
Someone suggested i remove the plastic shields when i did that all the motors came on but no movement also im getting the included images error
azab2c
(Aza B2C)
March 2, 2023, 8:32pm
26
Makes sense if they’re not plugged in.
@jcwinter27 , did you already see docs/electronics/skrpro/#disable-sensorless-pin ? The Diag Pin needs to be bent.
jeffeb3
(Jeffeb3)
March 2, 2023, 8:45pm
27
The diag pin bent only affects endstops, so not the root cause here.
vicious1
(Ryan)
March 2, 2023, 8:51pm
28
If you don’t bend that pin as AZA mentioned you can not plug in endstops or things get funky.
https://docs.v1e.com/electronics/skrpro/#disable-sensorless-pin
Is the black cable plugged in on your screen? which port, can you show me the back?
That error should only happen if you do not have the stepper drivers plugged in.
PS!! never plug or unplug anything into that board with the power on, you will most likely cause an issue so always power down and unplug it before doing anything.
vicious1
(Ryan)
March 2, 2023, 8:52pm
29
Also just to make sure can I see the port on the SKR pro that the driver plugs into. I want to see the jumper pins.
azab2c
(Aza B2C)
March 2, 2023, 8:58pm
30
+1, or $60 even. I killed my SKR board due to not powering down first before making changes.
I need a bit more direction on what exactly you want to see
vicious1
(Ryan)
March 2, 2023, 10:09pm
32
The empty socket where you pulled that driver out of.
And you should bend in all the driver pins from the link we posted.
What do you mean bend the pins
azab2c
(Aza B2C)
March 2, 2023, 11:16pm
34
I did this now all the board does is blink red lights
vicious1
(Ryan)
March 3, 2023, 7:18pm
36
Did what?
Can I see a picture of whatever you did.
vicious1
(Ryan)
March 3, 2023, 8:25pm
38
okay, found one issue. You are not wired right.
Did what? removed the plastic shields or bent the pins?
vicious1
(Ryan)
March 3, 2023, 8:31pm
39
You are not the first one to make that mistake, I just edited that picture in the instructions so it does not happen any longer.
Mist have accidently switched them when i pulled it out put it back in the correct 1 still blinking red
vicious1
(Ryan)
March 3, 2023, 9:47pm
41
jackhole:
I did this now
What does this mean. What did you do?
