Flyfisher604 Fusion 360 Post Processor (v2) is Available
Release V2 of the Flyfisher604 F360 post processor is available.
Release History
----- Github tag: v2 -----
  • Numerous bugfixes
  • Coolant channels reworked; allows for channels A and B to be enabled at the same time; allows a coolant type to be defined for a laser; coolant properties are unified to control either Marlin and Grbl firmware; warnings if tool’s requested coolant is not configured on a channel
  • SafeZ (G1 to G0 conversion) can reference the Heights defined in a tool operations
  • Enhanced comment levels
  • Firmware dialect selected as a property
  • Single file install via F360 standard Manage->Post Library install interface
  • Updated documentation
----- Github tag: v1 -----
  • G0 Rapid move at the beginning of each cut is restored - resolves tool drag when Z is not retracted before horizontal travel occurs (F360 Hobby issue)
  • Recovers G0 Rapids that occur above a safe height or that are vertical only (F360 Hobby issue)
  • Feedrates can be scaled to ensure mpcnc Z axis cut rate is not exceeded. Fusion 360 kinematics do not respect an axes feedrate if different from the machine’s generalized feedrate.
Warning:
  • User must review all GCode produced to ensure it is appropriate for their needs.
Documentation for v2 may be found here .
Here is a copy of Flyfisher604 v2 for easy reference
MPCNC.V2.zip (14.8 KB)
Once unzipped, mpcnc.cps can be installed using F360 Manage->Post Library. When running the PP use the Setup button to select Use Personal Post Library (will be remembered - required once).
Please report any issues to flyfisher604/mpcnc_post_processor Issues
