Has anyone used any furniture assembly fittings using there MPCNC/Lowriders?
Something like the Lamello Cabineos, Hafele Rafix and the Peanut by Intelligent Fixings.
They are designed for flat packed furniture and quick assembly. They are great for fitted furniture. I will add images tomorrow
I’ll show an example of chest of drawers made that will be part of a larger design.
Fabien
(Fabien)
August 11, 2024, 10:49pm
2
Sure, here you go…
I’m in the process of making a large bespoke shelf for my office
[image]
The cabinets would be made out of 16/18mm thick agglomerate boards (depending on what I can find/buy)
The depth of the cabinet should be around 30cm
I’m not really willing to cut everything out of a single sheet/panel, so I’ll probably go with pre-cut 30cm wide tablets and just cut the length according to my needs
As I want some of the tablets to be adjustable, and I may add doors at a later point, I would like this c…
VB34 worked perfectly and can be cnc’d flat in one operation
Also check out this plugin for f360
It makes life a lot easier when designing cabinets
@Fabien Thanks for the link to the thread, that’s awesome, the timing of it fell Into the period I stopped researching and started making. Your shelving unit came out awesome, I’ve personally only ever used Cabineo fixings but will try the Rafix style fixings soon, seems much more economical.
@Fabien
Everything including doors done on the Lowrider/mpcnc concoction.
Fabien
(Fabien)
August 12, 2024, 8:30pm
5
Very nice!
Those doors look just great!
Painted MDF?
Regarding the fixings, I think of you already own the cabineo system, it’s probably the best
Yeah sprayed them, CNC really makes things a lot easier, the bronze tinted glass doors were surprisingly simple to do.
Yeah I’ve used it for shelving and huge surprise in how much weight they can carry.
Fabien
(Fabien)
August 12, 2024, 10:23pm
7
Yeah… But did you cut your own handles ?
Recently bought the doors for our Ikea Pax dressing, and we were not sure about which handles we should get…
So naturally I set on making some handles with the LR3
The first one I did was in Jatoba wood, but my wife didn’t like the color at all, that’s the one on the right
The one on the left is probably what we will keep, this one is a bit thinner, and is made out of Tali wood, stained dark and coated with glossy varnish
[image]
[image]
Same Tali handle, but before it was staine…
lol stop teasing me.
I have to follow the clients instructions!
Fabien
(Fabien)
August 13, 2024, 7:50am
9
Haha, I know this feeling
That’s why I didn’t build the cabinets ans bought them, but insisted on making the handles in exchange
Also if you’re looking for drawer boxes and are up for a challenge, why not try some cnc’d finger joints or dovetails?
For the arbitrary shape joint, the boards need to be mounted vertically. You need access to the end of the board, so that will mean a slot in your table.
In the years since these posts I was thinking maybe dog-bone joints and some half-dowels could make clean joints with less work. I’m not a fan of the dog-bone gaps from an aesthetic perspective, but they should have repeatable, defined shapes that can be plugged quickly in bulk.
I have to try this one…
It might be doable with just Fusion 360 CAM too
Made a quick design in F360…
[image]
[image]
[image]
And the associated CAM
Male part, nothing too special here…
[image]
Female part - 3D adaptative cleaning with a straight bit
[image]
Female part - 3D ramp with a lollipop mill
[image]
The last operation is not perfectly adjusted yet, I need to work on this a little bit…
But you can see in simulation the ball correctly goes inside the dovetail
