I couldn’t agree more with how awesome the software is,
not to be taken in wrong context but for someone who is slow in the head due to accident , I find the simplicity of it beneficial for me to work out, im only using the basics of MM as i know if i dig deeper im likely to stuff something up and have to prob buy another V1 board as its easier to just buy new one than try work out why its not working , prob going have buy another one soon as want make a 2nd smaller machine
their support has also been awesome with every issue ive come across, even when its been dumb ass quesstions
I tried the ungroup on my drawings , but upon clicking on say centre box some were individual lines not rectangles as i thought they would be , will import some more drawings and try both options again see what happens
If you’re importing from DXF, some applications produce “line soup” instead of connected loops, and MillMage imports what it’s given, by default.
There’s a setting, under the Import/Export tab, called ‘Auto-Close Tolerance”. If you set that to anything that’s more than zero, any endpoints that are within that distance will be joined into a single shape. I have mine set to 0.01mm.
You can also do this manually in MillMage - Import a file, ungroup everything, then click Edit > Auto Join and it will do basically the same thing.
Yes i already downloaded it yesterday but honestly the ui reminded me Artcam. Need to play some with it. But im confident this will integrate easy with my work flow. 200xSeat.
cheers but the shipping cost from down here is the killer. its more expensive to send it just to you, let alone return than it is to buy another board and pay your shipping
its that board, one of the Y drivers wasn’t reading and couldn’t work out why.
was scrolling you tube one day and came across jd garage mini table this only uses 3 drivers, so thought might make the frame as a gunnie pig to play around with that jackpot board and try understand how gpios pwm etc all work, id like to understand all that stuff one day ,things like adding led for when’s its homed and in paused state , cant remember if i seen that here or on another site
and if i fry that board no biggie
i normally always use ungroup, without an issue. i think it probably more the different work benches in free cad not talking to each other correctly which could be causing my issues when separating the drawings in MM
For the people insisting on being difficult about their OS (like me): the current release candidate works fine on linux using bottles, but requires the winmgmt service to be started in the bottle. I did not test connection to the controller over serial.
The interface is familiar from lightburn, I did struggle a bit with different operations in a group of vectors, but managed fine in the end.
Love the visualizations in the operation menus.
Ramp Holding Tabs have no defaults for thickness and height, not quite sure about that decision but people more experienced with CAM need to make that decision.
cheers for the info it does seem to work for the most part but not on the side view, trying to get the inner panel but it breaks apart inner lines , all good ill just have to go back to old way, as said think its free cad issue as a svg file comes into MM as gibberish
I have to admit that those shorts on youtube make me wish I had spent alot of time with millmage. I took Monday and Tuesday off. I will need to try it then!!!
