Another New LR3 Build in Australia
ok, fresh unzip of the SKR PRO source builds with
BOARD_BTT_SKR_V3_0_EZ as the board in config.h
STM32H743Vx_btt as the environment in platform.io
Set “true” to invert status of all the endstops
now lets add this new define line In pins_BTT_SKR_V3_0_common.h, #define XMAX_PIN PC2
EDIT
yep, that was successful!
now lets load it to the board and see what we get!
Edit 2 added that i need to change the inversion state of the endstops to my list
Persistence!
Ok, still no Z2 showing after m119 command
Ok,
So i was looking at @jeffeb3 post and the code and i noticed that his line that i copied said
when i looked at the code after it failed (even though it built fine) i noticed that the line was actually
#define X_MAX_PIN PC2
so i made that change and reloaded the firmware
And…
Yeah baby!
It works!!!
Ok ignore the fact they are both not triggered, i can fix that once i level the gantry!
so the BIGTREETECH SKR V3 EZ is now working!
that was fun actually.
Thanks @vicious1, @jeffeb3 and the other people that chimed in.
the board will defiantly need some bug fixing to be an option for people, but yep it works.
Pretty happy and excited.
LOL
Edit
Well sorta working, the homing sequence does not work.
The gantry homes and once Z2 Limit Switch is hit, everything stops. If you manually hit the Z1 limits switch the whole gantry moves down goes for the 2nd slower pass.
So still some work to do!
But I am not going to let that stop me from going home and having a nice scotch and dry ( I don’t really drink, but celibration time, cos i got out of my comfort zone and did it!)
Congratulations! That is rewarding.
Did you verify all the endstops work on their own with M119?
Did you verify the Z1 motor is going to trigger the z1 endstop?
thanks! it was a good feeling.
Yes all Endstops are working
Yes, i had to add little M3 screws to adjust the endstop trigger points.
So a bit more on the Z height adjustment, if i run the Z homing sequence here is what happens
  1. Start the sequence
  2. The gantry moves up, if Z2 is triggered first both motors stop.
    2a. IF you manually trigger Z1 the operation continues and the gantry moves down and then back up until Z2 is triggered again, if you trigger Z1 in this process nothing happens and the gantry keeps going until Z2 is triggered again.
Run M119 and test each endstop individually. Sounds like Z2 is always triggered.
Yes I did that to test them after the firmware fun. I then went through and ran the M119 command for each limit switch, well twice actually. Once to trigger it then a second time to see that it was not triggered again.
Hmmm. That sort of sounds like the two Z motors are not on different drivers. But it doesn’t explain everything.
They are definitely running on separate physical drivers on the board, and plugged into those separate ports on the motherboard.
But that does not mean they are not “linked” or something in the firmware, how can we check for this?
Are you sure, two of the Z ports are connected. It is probably best if you show us a picture of how it is wired.
Ok, well I can guarantee that the 5 motors are wired separately, hopefully is just me being stupid or software link i have missed in the firmware
And a side shot of the drivers (hot glue too make sure they stay put, it just peels off)
So i was.jusr reading this again, do you mean there is a port on the board that “duplicates” the other z axis?
I was wondering why there was another driver port on the board.
I will see if i can find something inbthe manual for the board.
So it looks like there iS
Z MOTOR A
Z MOTOR B
E MOTOR A
E MOTOR B
The manual does not mention a connection hardware wise, but that does not mean i have not left a software version of that in the firmware build
I know this is the SKR V3 EZ board, but on my Ender 3, I put in an SKR mini e3 v2, and it has 5 plugs for the motor (1X, 1Y, 2Z, 1E). The 2Z plugs are actually paired, and are not driven independently, but the board controls them at the same time. I think this is what Ryan was referencing making sure the drivers you have run each motor independently. A lot of the boards like to “have dual Z” for printers, but they aren’t really Dual Z.
Your Z2 motor should be on E motor b.
If Z1 stops working at that point there is a minor edit to do but I am not sure how they wired the ports. Lately they have been in series with jumpers.
Ok, thats an easy change, that is the port on the far side. I can make that change this morning and test.
I will test smd report back
Ok,
I got to work a bit early and made that change, and sure enough that was the answer, but i had to swap directions on the stepper plug, i suppose that can be added to the list of changes to the firmware, but its just as easy to swap the plug.
There was a bit of a problem around limit switches, Which took me a while to figure out.
Z1 limit switch now stops Z2 motor which is super odd. Again an easy fix, swap the limit switches, i should get some time at lunch to do that and do around test.
Super Happy!
Soooooooo Close now.
