Zero point configuration in MillMage
Can anyone tell me the correct corner for the zero point configuration in MillMage?
Thank you.
In MillMage whenever you open to start a new project it asks you where you would like have it set. I use lower left since for me it’s the easiest to align.
Did you have a more specific question on that?
Under Device Wizard there is a section where you set the Zero Point Configuration, I have this set to the front left as this is what I also use for my origin. The issue I am having is MillMage always throws an out of bounds error message for every cut I do. I just click through the message and the programs works as expected but it is agervating.
Thank you for the reply.
Bob F.
I have mine set to the front left too. I get that message also. Hopefully they figure out the problem before the next update.
Do you have your machine size set properly in the device settings?
Yeah, getting the same error here occasionally. Been ignoring it so far since I am working on bigger bugs to squash at the moment.
Yes I do, I actually made sure that is correct during the trouble shooting process.
did you sort your prob
With the latest MillMage RC I am no longer receiving the OOB error message when I try to run a file. I have not used the newest version yet just did a quick test for this error message.
This weekend will tell us more.
I am still using the left front corner for the Zero Point Configuration in MillMage.
