Zero G Mercury One.1 Build
Have you decided to build you one yet?
No, the “kit” is sold out at the moment and with the extra costs of import to here it gets expensive.
I’ve seen some kits on Aliexpress as well if that helps any
It might, could you link a “kit” on aliexpress? :slight_smile:
I went with the E34M1 toolhead with a Revo and orbiter 2. I finally got it all together now just working out the kinks.
That’s the tool head and extruder I used on my E5+, but with a Rapido HF. I never change nozzles so no need for the expensive revo nozzles for me. I decided to try out the EVA 2.4 on the E5Pro but same Orbiter V2 and Rapido HF.
Ive also got revo on my switchwire conversion I just like to keep things the same so I don’t have a bunch of different stuff to change or keep up with.
Are you happy with the extruder and hotend combo?
Very much so. Not one signal clog ever. With the filament sensor on the orbiter its extremely easy for a filament swap. With a .6mm CHT nozzle it flows crazy high amounts. Ran a max flow test in orca to 50mm³ and it wasn’t even slowing down at that point.
I’ve decided to try this myself. Seems exiting.
Awesome!! Good luck!!!
Do you have any advice? Like things to not do?
They have much better build docs now so it should be a lot easier for you. Biggest thing is make sure all your pulleys move really good when you get it all together and tightened down. And you can either go with the EVA 2.4 tool head or the E34M1. I have built both but haven’t gotten to use the 2.4 yet. There are other options out there but I have no experience with them. There is a good bit of activity on the zero g discord so you can usually get questions answered there pretty quickly. Plus there is a ton of community mods there as well.
Hello, great looking build, what mount are you using for your screen and what size screen is that?
It’s the BTT HDMI 5 and it’s one I got from the community section on the ZeroG discord. They have them for several different screens
Did you use/re-use the micro swiss x-carriage? Or did you print something else?
No that all gets changed when you do the conversion. The old micro swiss was built to run with the V wheels on the original ender 5 setup. With the conversion you now have a linear rail on X and Y. Also the belt path is completely different with corexy vs the stock setup.
