Hello. I’ve recently swapped over my controller to a Jackpot V1 based on a lot of recommendations here.
After a weekend of troubleshooting and inching closer towards a working machine, I nearly have everything homing properly. The problem I’m having is the Z axis is getting to the top of travel and stalling on the Z0 motor side, making a horrible noise, and then triggering an alarm. I’ve checked wiring, and I can see the Z0 (gpio.32) indicator LED on the Jackpot triggering properly, so I don’t think wiring is the issue. It’s also triggering as expected on Z1 (gpio.34), where it seems to be stopping as expected. All endstops are wired as NC.
Configuration is default and havent fiddled with pulloff settings yet, but would also appreciate advice on how to completely reset my Jackpot config to factory just in case I’ve put a setting wrong somewhere.
Starting to panic a bit as I’ve got a client project due at the end of the month. Help appreciated.
config.yaml and console log below:
board: Jackpot TMC2209
meta: 10-31-2024 RyanZ
planner_blocks: 32
stepping:
  engine: I2S_STATIC
  idle_ms: 255
  pulse_us: 2
  dir_delay_us: 1
  disable_delay_us: 0
uart1:
  txd_pin: gpio.0
  rxd_pin: gpio.4
  rts_pin: NO_PIN
  baud: 115200
  mode: 8N1
axes:
  shared_stepper_disable_pin: NO_PIN
  x:
    steps_per_mm: 50.000
    max_rate_mm_per_min: 9000.000
    acceleration_mm_per_sec2: 200.000
    max_travel_mm: 1260
    soft_limits: false
    homing:
      cycle: 2
      positive_direction: false
      mpos_mm: 3
      feed_mm_per_min: 300.000
      seek_mm_per_min: 1500.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    #X
    motor0:
      limit_neg_pin: gpio.25:high
      limit_pos_pin: NO_PIN
      limit_all_pin: NO_PIN
      hard_limits: false
      pulloff_mm: 4.000
      tmc_2209:
        uart_num: 1
        addr: 0
        cs_pin: NO_PIN
        r_sense_ohms: 0.110
        run_amps: 0.800
        homing_amps: 0.800
        hold_amps: 0.700
        microsteps: 8
        stallguard: 0
        stallguard_debug: false
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        run_mode: StealthChop
        homing_mode: StealthChop
        use_enable: false
        direction_pin: I2SO.1
        step_pin: I2SO.2
        disable_pin: I2SO.0
  y:
    max_travel_mm: 2480
    soft_limits: false
    homing:
      cycle: 2
      mpos_mm: 3
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    #Y
    motor0:
      limit_neg_pin: gpio.33:high
      hard_limits: false
      pulloff_mm: 4.000
      tmc_2209:
        uart_num: 1
        addr: 1
        cs_pin: NO_PIN
        r_sense_ohms: 0.110
        run_amps: 0.800
        homing_amps: 0.800
        hold_amps: 0.700
        microsteps: 8
        stallguard: 0
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        use_enable: false
        step_pin: I2SO.5
        direction_pin: I2SO.4
        disable_pin: I2SO.7
    #A
    motor1:
      limit_neg_pin: gpio.35:high
      hard_limits: false
      pulloff_mm: 4.000
      tmc_2209:
        uart_num: 1
        addr: 3
        cs_pin: i2so.14
        r_sense_ohms: 0.110
        run_amps: 0.800
        homing_amps: 0.800
        hold_amps: 0.700
        microsteps: 8
        stallguard: 0
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        use_enable: false
        step_pin: I2SO.13
        direction_pin: I2SO.12
        disable_pin: I2SO.15
  z:
    steps_per_mm: 200.000
    max_rate_mm_per_min: 1800.000
    max_travel_mm: 300.000
    soft_limits: false
    homing:
      cycle: 1
      positive_direction: true
      mpos_mm: 3
      feed_mm_per_min: 200.000
      seek_mm_per_min: 800.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      limit_neg_pin: NO_PIN
      limit_pos_pin: gpio.32:high
      hard_limits: false
      pulloff_mm: 4.000
      tmc_2209:
        uart_num: 1
        addr: 2
        cs_pin: NO_PIN
        r_sense_ohms: 0.110
        run_amps: 0.800
        homing_amps: 0.800
        hold_amps: 0.700
        microsteps: 8
        stallguard: 0
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        use_enable: false
        step_pin: I2SO.10
        direction_pin: I2SO.9
        disable_pin: I2SO.8
     #B
    motor1:
      limit_pos_pin: gpio.34:high
      hard_limits: false
      pulloff_mm: 4.000
      tmc_2209:
        uart_num: 1
        addr: 3
        cs_pin: i2so.19
        r_sense_ohms: 0.110
        run_amps: 0.800
        homing_amps: 0.800
        hold_amps: 0.700
        microsteps: 8
        stallguard: 0
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        use_enable: false
        step_pin: I2SO.18
        direction_pin: I2SO.17
        disable_pin: I2SO.16
#  c:
#    steps_per_mm: 80.000
#    max_rate_mm_per_min: 5000.000
#    acceleration_mm_per_sec2: 100.000
#    max_travel_mm: 300.000
#    soft_limits: false
#    homing:
#      cycle: 0
#      positive_direction: true
#      mpos_mm: 150.000
#      feed_mm_per_min: 100.000
#      seek_mm_per_min: 800.000
#      settle_ms: 500
#      seek_scaler: 1.100
#      feed_scaler: 1.100
#    motor0:
#      limit_neg_pin: gpio.39:low
#      limit_pos_pin: NO_PIN
#      limit_all_pin: NO_PIN
#      hard_limits: false
#      pulloff_mm: 3.000
#      tmc_2209:
#        uart_num: 1
#        addr: 3
#        cs_pin: i2so.22
#        r_sense_ohms: 0.110
#        run_amps: .8
#        homing_amps: 0.800
#        hold_amps: 0.050
#        microsteps: 16
#        stallguard: 0
#        stallguard_debug: false
#        toff_disable: 0
#        toff_stealthchop: 5
#        toff_coolstep: 3
#        run_mode: StealthChop
#        homing_mode: StealthChop
#        use_enable: false
#        step_pin: I2SO.21
#        direction_pin: I2SO.20
#        disable_pin: I2SO.23
i2so:
  bck_pin: gpio.22
  data_pin: gpio.21
  ws_pin: gpio.17
spi:
  miso_pin: gpio.19
  mosi_pin: gpio.23
  sck_pin: gpio.18
sdcard:
  cs_pin: gpio.5
  card_detect_pin: NO_PIN
  frequency_hz: 20000000
probe:
  pin: gpio.36:low
  toolsetter_pin: NO_PIN
  check_mode_start: true
start:
  must_home: false
coolant:
  flood_pin: gpio.2
  mist_pin: gpio.16
  delay_ms: 0
control:
  safety_door_pin: NO_PIN
  reset_pin: NO_PIN
  feed_hold_pin: NO_PIN
  cycle_start_pin: NO_PIN
  macro0_pin: NO_PIN
  macro1_pin: NO_PIN
  macro2_pin: NO_PIN
  macro3_pin: NO_PIN
macros:
  startup_line0:
  startup_line1:
  macro0:
  macro1:
  macro2:
  macro3:
user_outputs:
  analog0_pin: NO_PIN
  analog1_pin: NO_PIN
  analog2_pin: NO_PIN
  analog3_pin: NO_PIN
  analog0_hz: 5000
  analog1_hz: 5000
  analog2_hz: 5000
  analog3_hz: 5000
  digital0_pin: gpio.26
  digital1_pin: gpio.27
  digital2_pin: NO_PIN
  digital3_pin: NO_PIN
#Laser:
#  pwm_hz: 5000
#  output_pin: gpio.27
#  enable_pin: NO_PIN
#  disable_with_s0: false
#  s0_with_disable: true
#  tool_num: 0
#  speed_map: 0=0.000% 255=100.000%
#  off_on_alarm: true
# pwm:
#  pwm_hz: 5000
#  direction_pin: gpio.26
#  spinup_ms: 0
#  spindown_ms: 0
#  tool_num: 0
#  speed_map: 0=0.000% 1000=100.000%
#  off_on_alarm: false
# 5V out gpio.26/27
# VMot out gpoi.2/16
# In's left to right gpoi.25/33/32/35/34/39/36
Commands
$G
$SS
[MSG:INFO: FluidNC v3.9.1 https://github.com/bdring/FluidNC]
[MSG:DBG: Running after-parse tasks]
[MSG:DBG: Checking configuration]
[MSG:INFO: Machine LowRider]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (3.000,1263.000)]
[MSG:INFO:   Motor0]
[MSG:DBG: TMCStepper Library Ver. 0x703]
[MSG:INFO:     tmc_2209 UART1 Addr:0 CS:NO_PIN Step:I2SO.2 Dir:I2SO.1 Disable:I2SO.0 R:0.110]
[MSG:INFO:  X Neg Limit gpio.25]
[MSG:INFO: Axis Y (3.000,2483.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:1 CS:NO_PIN Step:I2SO.5 Dir:I2SO.4 Disable:I2SO.7 R:0.110]
[MSG:INFO:  Y Neg Limit gpio.33]
[MSG:INFO:   Motor1]
[MSG:INFO:     tmc_2209 UART1 Addr:3 CS:I2SO.14 Step:I2SO.13 Dir:I2SO.12 Disable:I2SO.15 R:0.110]
[MSG:INFO:  Y2 Neg Limit gpio.35]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:2 CS:NO_PIN Step:I2SO.10 Dir:I2SO.9 Disable:I2SO.8 R:0.110]
[MSG:INFO:  Z Pos Limit gpio.32]
[MSG:INFO:   Motor1]
[MSG:INFO:     tmc_2209 UART1 Addr:3 CS:I2SO.19 Step:I2SO.18 Dir:I2SO.17 Disable:I2SO.16 R:0.110]
[MSG:INFO:  Z2 Pos Limit gpio.34]
[MSG:DBG: X Axis StealthChop]
[MSG:VRB: CHOPCONF: 0x15020053]
[MSG:VRB: COOLCONF: 0x0]
[MSG:VRB: TPWMTHRS: 0x0]
[MSG:VRB: TCOOLTHRS: 0x0]
[MSG:VRB: GCONF: 0x1c0]
[MSG:VRB: PWMCONF: 0xc10d0024]
[MSG:VRB: IHOLD_IRUN: 0x11915]
[MSG:DBG: Y Axis StealthChop]
[MSG:DBG: Y2 Axis StealthChop]
[MSG:DBG: Z Axis StealthChop]
[MSG:DBG: Z2 Axis StealthChop]
[MSG:INFO: Connecting to STA SSID:xxxxxxx]
[MSG:INFO: Connecting.]
[MSG:INFO: Connected - IP is 192.168.xxxxxx]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:http://fluidnc.local/]
[MSG:INFO: Probe gpio.36:low]
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Pn:Z|WCO:0.000,0.000,0.000>
$HZ
[MSG:DBG: Homing Cycle Z]
[MSG:DBG: Starting from 0.000,0.000,0.000]
[MSG:DBG: Planned move to 0.000,0.000,-4.000 @ 200.000]
[MSG:DBG: CycleStop PrePulloff]
[MSG:INFO: ALARM: Homing Fail Pulloff]
ALARM:8
Homing fail. Pull off travel failed to clear limit switch. Try increasing pull-off setting or check wiring.
ok
<Alarm|MPos:0.000,0.000,-4.000|FS:0,0|Pn:Z|Ov:100,100,100>
$HZ
[MSG:DBG: Starting from 0.000,0.000,-4.000]
[MSG:DBG: Planned move to 0.000,0.000,-8.000 @ 200.000]
[MSG:DBG:  Z Pos Limit 0]
[MSG:DBG: Homing nextPhase FastApproach]
[MSG:DBG: Starting from 0.000,0.000,-8.000]
[MSG:DBG: Planned move to 0.000,0.000,322.000 @ 800.000]
[MSG:DBG:  Z Pos Limit 1]
[MSG:DBG: Homing limited Z]
$HY
[MSG:DBG: CycleStop FastApproach]
<Home|MPos:0.000,0.000,322.000|FS:0,0|Pn:Z>
[MSG:INFO: ALARM: Homing Fail Approach]
ALARM:9
Homing fail. Could not find limit switch within search distances. Try increasing max travel, decreasing pull-off distance, or check wiring.
ok
[MSG:DBG: Homing Cycle Y]
[MSG:DBG: Starting from 0.000,0.000,322.000]
[MSG:DBG: Planned move to 0.000,-2728.000,322.000 @ 1500.000]
<Home|MPos:0.000,-0.200,322.000|FS:1500,0|Pn:Z>
[MSG:DBG:  Y Neg Limit 1]
[MSG:DBG: Homing limited Y Z]
[MSG:DBG:  Y2 Neg Limit 1]
[MSG:DBG: Homing limited Y Z Y2]
[MSG:DBG: Homing nextPhase Pulloff0]
[MSG:DBG: Starting from 0.000,-4.600,322.000]
[MSG:DBG: Planned move to 0.000,-0.600,322.000 @ 300.000]
[MSG:DBG:  Y Neg Limit 0]
[MSG:DBG:  Y2 Neg Limit 0]
[MSG:DBG: CycleStop Pulloff0]
[MSG:DBG: Homing nextPhase SlowApproach]
[MSG:DBG: Starting from 0.000,-0.600,322.000]
[MSG:DBG: Planned move to 0.000,-5.000,322.000 @ 300.000]
[MSG:DBG: Homing limited Z Y2]
[MSG:DBG: Homing nextPhase Pulloff1]
[MSG:DBG: Starting from 0.000,-4.580,322.000]
[MSG:DBG: Planned move to 0.000,-0.580,322.000 @ 300.000]
[MSG:DBG: CycleStop Pulloff1]
[MSG:DBG: Homing nextPhase Pulloff2]
[MSG:DBG: mpos was 0.000,-0.580,322.000]
[MSG:Homed:Y]
[MSG:DBG: mpos becomes 0.000,3.000,322.000]
[MSG:DBG: mpos transformed 0.000,3.000,322.000]
[MSG:DBG: Homing done]
ok
$HX
[MSG:DBG: Homing Cycle X]
[MSG:DBG: Starting from 0.000,3.000,322.000]
[MSG:DBG: Planned move to -1386.000,3.000,322.000 @ 1500.000]
[MSG:DBG:  X Neg Limit 1]
[MSG:DBG: Homing limited X Z]
[MSG:DBG: Starting from -4.080,3.000,322.000]
[MSG:DBG: Planned move to -0.080,3.000,322.000 @ 300.000]
[MSG:DBG:  X Neg Limit 0]
[MSG:DBG: Starting from -0.080,3.000,322.000]
[MSG:DBG: Planned move to -4.480,3.000,322.000 @ 300.000]
[MSG:DBG: Starting from -4.040,3.000,322.000]
[MSG:DBG: Planned move to -0.040,3.000,322.000 @ 300.000]
[MSG:DBG: mpos was -0.040,3.000,322.000]
[MSG:Homed:X]
[MSG:DBG: mpos becomes 3.000,3.000,322.000]
[MSG:DBG: mpos transformed 3.000,3.000,322.000]
ok
<Idle|MPos:3.000,3.000,322.000|FS:0,0|Pn:Z>
