Z axis movement is not correct
First of all, thanks to Ryan for the incredible work!
I’ve been busy building my MPCNC for a few weeks now and until now everything is working really great(And yes, I’m building the thing in my office room - my wife hates me - but in the spring we’re moving to a house where I can call a workshop my own… ).
However… I just noticed today during the first real test cut in wood that the Z axis travel is not correct. Previously, when drawing with the pen, I have not noticed it of course, because there the Z axis is not needed much.
I use CNCJS for control, Estlcam generates the Gcode. Here is a section of my Estlcam settings, if that matters at all. Sorry, cant upload more than 1 Photo as a new User:
steps per unit: x = 6400, y = 6400, z= 3200
Way per Unit: x = 32mm, y= 32mm, z= 2 mm
Now I noticed while milling (in Estlcam 3mm milling depth in 3 steps à 1 mm set) that the milling depth is not correct (has milled about 1 mm deep).
Now I have checked the following:
If I move the axes 10 mm in CNCJS, the axes move as follows:
X axis = Exactly 10 mm - Perfect!
Y axis = Exactly 10 mm - Perfect!
Z axis = Approx. 3 mm!
So this is off by about a factor of 3.xxx.
M503 returns me the following values:
“echo: Steps per Unit: M92 X200.00 Y200.00 Z800.00”
the coupler is fixed and secured with locktite.
My hardware (unfortunately not purchased from Ryan…shipping USA-Switzerland, lockwdown etc.):
- Ramps 1.4 with Arduino Mega
- Firmware: MPCNC_Ramps_T8_16T_LCD_32step_DualEndstop
- 4x Endstops
- TR8 x 2mm Leadscrew
- Steppers: Nema 17 42HS60-1704A (1.8, 1.7A, 0.7 Nm)
- DRV 8825 Drivers (All jumpers set → 32 steps)
- Currently a Dremel for testing purposes - AMB 1050 is on the way
I have read across the forum and am now more confused than ever.
I really hope someone can help me with this!
Sorr for my English - not a native speaker
Thanks a lot in advance!
