Z axis travel and asse
Also, I’m not sure that sort of cable management is absolutely necessary but for me I thought it was a good idea, so I spent the extra time to make it and run everything through it.
Note: I knew from the start I wanted to use the Kobalt router. Hence the color scheme I chose for the printed parts.
Note: You should not connect the chain to your Z a the top. This could affect stability. Fasten it to the core (you can see that in my pictures it is fastened to the core at the bottom).
Good tip! I initially wondered about that but then didn’t think more about it. I’m still tweaking things, so I can move it easily.
Oh, I see the picture in your previous post. Do you have downloadable a print file for it?
They are in the Schneewittchen thread somewhere. I can look in the afternoon. Gotta go to work now. :slightly_smiling_face:
Danke, I found them. If anyone is looking, they are here:
