Hi everyone. I built the machine with
36x36x6 built volume. Loaded marlin available from Vicious1.
All Steppers work fine aside z and extruder motors getting quite hot.
Z-motor making weird noise when stop time to time.
But the real problem is that at the beginning of a print the z is first plunging past the bed.
Is there a fix in g-code?
Is there a way to permanently fix zeroing to correct heights?
I use the 2250 drivers set to 2A per drivers spec.
It is weird that the x and y motors stay cool with the same settings but a is getting hot.
Extruder motor I set to 1A as I just don't know the specs. Got some generic mk9 and it did not have any spec sheets included, so I just went ahead and reduced the amperage just in case.
As far as z Plunge, I do reset through LCD controller when machine starts ( and I move my head to desired location first, nozzle just touching the table).
Still, when process starts, head goes down past table first the raised up and tries to print in the air.
I do not have end switches installed.
Overall z is 12". Frame tube over table (center of lower axis tube) is at 8.75"
Maybe I have a moving wrong direction?
How do I switch it backwards? Just flip the plug?
Thank you much for all the work you out into this project!!!
2A is the rated max usually meaning they will want to run almost 100C above ambient if I remember right. I would dial that down to 80% or so and go up from there depending on stepper temps while in use. Dial them all down until they are warm not hot, I know that isn’t an exact number but it does seem to be the best way. Not all the steppers get used the whole time so the percentages will vary.
I’m not sure what could be happening to your z axis you should include some of your beginning gcode, that should so what is going on. How are you generating it?
I have the same problem, I think I need to focus on figuring that out, did you ever figure it out? I tried the test file under software in assembly instructions and that seemed to work, but when I take a vector image through the estlcam export for repitere then start the print and it just keeps going down on the x till I have to kill it before it pushes through the table…
