Hi,
i encountered a very strange problem today. When I selected home Z axis the carriage went up a mm or so then stopped. After fiddling around I found if i turned the spindle power supply off at the mains everything worked fine. I have just fitted a Machifit 500 watt 100 volt motor, controller seems pretty basic, is it possible it puts out enough electrical noise to screw up homing?
Dave
