I’m a bit desperate with my LowRider V4 at the moment. I am using ESTLCAM for gcode generation. I load the finished gcode into fluidnc and start the job there.
Now I do the homing and then the probing. After probing, I start the job.
However, the milling cutter always plunges 2 mm too deep into the workpiece. I have entered a depth infeed of 1 mm for the tool in my job in ESTLCAM. Nevertheless, the milling cutter plunges 2 mm into the workpiece in the first pass and the offset of one millimeter then continues throughout the entire job.
What could I have set incorrectly or what can I check?
Your gcode looks fine, I was checking you had probe thickness set correctly.
Maybe check if this is related to cutting load. What happens if you probe/zero the machine (you can enter the G38.2 Z-110 F200 P0.5 in the console) home it ($HZ), and drive it back to 0 (G0 Z0)? Does it push into the material/lift your Y-cart up?
If you got the leadscrews from the V1 store and are using the V1 config files, you shouldn’t have to do anything.
I’m guessing this is a case of either the Z motors skipping steps (need to lube the leadscrews) or the leadscrews slipping (need to tighten the grub screws). When either of these occur, they are more likely to happen when Z is at the bottom and moving up. You might not have seen an issue with the earlier test because homing is slower.
I think Jason is on the right track. I had a similar issue with my Primo but it was stairstepping down. I am not sure of the final solution, but I checked grub screws, lubed, and increased my stepper current and the issue went away. Here is the post if you are interested. Z height issue
ok, thanks, will check that.
But if the Z-motors would skip steps, would that not happen moving the gantry upwards? The first pocket with 1mm depth is also 1.5 mm deep and the gantry moves down all the way to the 1.5mm. As this pocket is milled in only one layer, there is no movement of the gantry - and so the z-axis motors where steps could be lost?
It’s reproducable, ran the same job three times and homed everything inbetween and also did the probing.
How do you increase the stepper current at the Jackpot board? I’m pretty sure there is a documentation somewhere explaining that and in which boundaries the current should be set?
My theory, and maybe others don’t agree, is that with an upcut bit and gravity, it will pull the gantry down. In my case it was going deeper when it hit corners which is where more of the bit is in contact. Again, your case may be different. One thing you could try is to ramp down instead of a straight plunge and see if that makes a difference.
This should absolutely not be happening. I put 10kgs on the gantry before and it didn’t lose steps. Also, my gantry is 3mm thick pipes with 1220mm cutting area, so significantly heavier than those with 1.5mm walls and there is no dropping or losing steps because of that. So no, an endmill can’t pull it down.
What is more likely happening in that case is that the work piece isn’t attached well enough to the spoilboard, so it’s pulling the work piece up from the spoilboard.
My workpiece is attached to the spoilboard with several screws (one of them 1.5 cm away of the first pocked drilled). Also the endmill is a very small one (diameter of 1.5 mm, 4 flutes). Shouldn’t pull that much at the workpiece?
Yes i know, still looking where to source endmills here in germany. I’m using the MAKITA RT0702C. My endmills with a little bigger diamater are single fluters or 2 fluters. Didn’t get one with such a small diameter till now
