A couple of times now, my y-limit switches are constantly open.
Homing of Y fails due to a failed back off, $limits shows both y and Y detected. Manually toggling the switches does nothing - I hear them click, but it doesn’t show up in the software.
What Jackpot board do you have? What version of FluidNC do you have? Is this something that just started or has always happened? Did anything change on your end?
This last time I requested a home on all axes 3 or 4 times, the y gantry kept scooting back and then saying something about homing fail pulloff.
That’s when I opened up $limits and saw that y and Y were continuously active even when clicked etc, but other axes detected switch activation properly.
The next time it happens I can also check the voltage on the headers with a multimeter and manually short the pins with a jumper.
That means your endstops are open. The endstops should show active when the contacts are open. My first guess is checking to make sure all your connections are good. the extension wire is a good place to start and after that make sure the endstops work, continuity test.
It happened again, on the Z1 motor, right after a new flash.
In this video I demonstrate that it’s stuck even if I disconnect the wire from the board, so it’s not a short.
In this video I demonstrate that a power cycle resolves the stuck limit switch.
Conveniently this happened shortly after a boot, so I have the full logs:
I did use the hose once before grounding, when cutting out the plates, so unfortunately I cannot fully rule out static discharge. I had thought the hose was out of the way enough to not cause problems:
Hmm. The inputs are protected and I can’t think of any way for them all to have random issues.
Can you upload a picture of your board all wired up please. I get the it is a bit messy from debugging, but a general cleanup of how you run it might help.
Where is your vac hose grounded to?
Are you using the router control on the Scienci router?
Not as a rule. I mean, they’re right next to each other and can touch, but there is no contact right now when I checked, so there was no contact in the most recent incident.
