Hello,
When I home X or Y and I’m quite far from the end switches the RAMBO board seems to time out and makes me reset. If I’m ~12"s away it works fine, no problems. Is there a firmware fix to this or is it a different issue?
Thank you
Hello,
Thank you
In the firmware you can set the machine dimensions, right now it is set at 200mm I think.
That’s right answer, i solved same issue. I think it would be nice to add this hint to firmware page
