Hello, I have an earlier version of the Burly MPCNC. I had it up and running, cutting parts but I replaced some parts on the frame. After putting it all back together the X-Y paths are not at right angles to each other, when i try to cut a square, the end shape is not square but rather rhombus shaped. I can cut two parallel lines in the x-direction and in the y-direction but as soon as i turn the corner to cut from x to y or vice versa, the cuts are not at right angles.
My running theory is when I reinstalled the belt i may have stretched it too much compared to its previous state.
Any ideas would be greatly appreciated, thank you!
THank you for the reply.
If you could link the autosquaring instructions that would be great.
I purchased this CNC second hand, i have the hardware and switches to do end stops and its something i want to dig into.
I highly suggest not doing any of that until you need that kind of precision though. So some basic cuts and some carves to get a feel for it, before adjusting the endstop offsets.
