Hi,
I have a dual endstop Rambo setup, recently I built an enclosure to contain the noise a bit more but have not changed any part of the wiring or setup so far. At every major step of the project I powered up the Rambo and made sure everything is ok, and just before I called it a day I found that my homing sequence isn’t working correctly.
I have successfully used this machine several times and the Y/Z axis seem to be fine but when I home everything, motor X1 (closest to me when looking at the machine) doesn’t move and grinds the belt, I can move the X axis in the UI perfectly fine and the motor locks up when it is made to move which makes me think the motor and connection is fine, but I’m not sure where to start troubleshooting.
I have dual endstop marlin firmware
Thanks!
Joe.
