Wifi lost
Hello,
I am having a lot of trouble performing the initial configuration of the jackpot3 card on LR4 (it was much easier with the miniRambo on MPCNC).
This is the second time I have lost the card’s WiFi signal (the FluidNC WiFi is no longer visible on either my laptop or my smartphone), even after restarting the card several times. The first time, I flashed the firmware (-> latest version v4.0.1) and was able to reconnect to the card via Wi-Fi. But this time, I can’t see the Wi-Fi network after flashing the firmware. However, everything seems fine in the “Wi-Fi” tab when I connect to the card via USB…
In short, I don’t really know what to do… this card seems very unstable to me…
For your information, the last code I ran was Jason’s code to automate Z-leveling. During the operation, the machine forced the Z-stops once, as if they weren’t working (even though they were working fine at the start of the operation). Then the machine went into standby mode. And the Wi-Fi connection was lost a few minutes later…
There’s a bug in FluidNC that broke this script starting in v3.9.5.
FluidNC v4.0 is not stable yet. Use v3.9.9.
What do you mean by standby mode?
Okay, thank you very much. I’ll skip this version.
When I say “standby,” it’s because the machine seems to have finished executing the GCode and is waiting for further instructions… which is perfectly normal!
Is your board configured for STA → AP mode?
Yes
So, I tried installing 3.9.4 (to benefit from Jason’s script), then updating the config.yaml files, etc. → WiFi undetectable.
Then I updated 3.9.4 without updating the files → OK.
One of the files must have been corrupted…
