What are you guys using for cnc control?
Real dumb noob here:
Are you using estlcam and then estlcnc? I made a crown, but now I don’t know how to upload it to my machine.
We need some more detail on your machine (particularly the controller) to answer your question.
Generally, folks here use Estlcam to generate the gcode, then either the webUI to transfer it to the Jackpot board, or an SD card to move it to the other older controllers. There are a lot of possible exceptions to this workflow. The “yellow brick road” approach is spelled out in the CNC Software Basics section of the Docs.
novice here, i was using estlecam but couldn’t get my head around it ,
I now use MillMage by lightburn, its still in development stage , but it dose what i need at present and you can connect direct to fluid nc via wifi , currently free to use in development stage
They just released RC8 which has some bugs, RC7 works fine
There is a crown gcode here somewhere. You can copy and go. No estcam needed. Kind of our benchy here.
Ok, I copied it to the sdcard and then used the web interface to run the code from the sdcard. I’ll try millmage as well. Thanks all!
You do know it is customary to post a pic of the crown, right?
:grin:
welcome to the fold!
