good evening,
I need your help to be able to solve a problem.
My mpcnc works fine, but I found a small inaccuracy in the cut piece:
cutting any shape I noticed that there are some tenths of a millimeter in less …
I found that everything is due to a vibration when the machine works in a diagonal …
Some happened? To sort out where should you look? firmware or CAM (Estlcam)
the vibration is due to the material too hard but the speed seems slow … leading engines to work almost jerky instead of a controlled, gentle movement
You’re right, I apologize, I correct it right away
My Mpcnc is self-built so I did not buy anything from your site, also because of customs duties.
The CNC is version 525 with 23.5 tubes, the same as planned, as electronic use an Italian board Alligator 32bit with Italian MarlinKimbra modified firmware, which has the same characteristics than normal Marlin. I use the value indicated here
Use endstop NC on all axes and set my zero" with G92 X0 Y0 Z0 …
Tonight see also post a video of the problem.
However everything seems to be due to the movement of step motors, which in the movement to 280mm / s Estlcam causes the wobble tool
the problem appears to be larger if it moves up if it goes fast is not very noticeable … but you see gt2 belts vibrate very
