My son bought himself a van - camping, surfing and carting a drum kit to gigs - so we decided to try a simple fitout for it. Started with ceiling racks for a couple of surfboards and fishing rods and moved up to a steel framed bed that opens up from sofa/single to a double. Intent is to use it a little before we look at further additions/modifications.
All in all a couple of fun days together as he learnt to Mig weld and play with the lowrider…
The lining solutions point is useful. I’m planning a simple fitout for a short-wheelbase Transit that’s mostly weekend trips around the North Shore, so I’m weighing plywood lining against something lighter that won’t trap damp behind it. One concern is airflow in a small van with the bed platform taking up most of the space, and I’m also stuck on whether a roof vent is worth cutting a hole for. Separately, I came across Best Fan For Bedroom of 2026 while trying to compare fan specs, though I’m not sure how well those ratings translate to a van cabin. Anyone run a vented setup in a SWB? Thanks.
Here’s a bit of feedback based on fifty-something years of camping in the back of a panelvan!
When we were young (and perhaps stupid) our van was insulated just like @Lurch’s sons, and we spent many a morning drying our gear after interior condensation storms. It was fun, cheap, and we wouldn’t have it any other way.
Now, more than fifty years later, insulation is everything! Even for a simple fitout some basic insulation will change your life.
Our van isn’t for work, so I used 3mm ply after insulating it (I didn’t insulate the structural cavities, which I would have done for extreme cold but it’s been great so far tested between -3 and +38°C)
I added strips of either curved pine or double ply to add rigidity to places I wanted to mount stuff, but the curve of the van makes it completely stiff.
Insulation - one layer of CarBuilders 3mm sound deadener, to all sheet metal sides, roof and cockpit floor, and one layer of Carbuilders Vanliner (foil backed half inch foam) everywhere else including the load area floor, followed by carpet liner on the visible surfaces applied in a single piece to each side.
We’ve never had any luck with vents, the best set up is to have two, with fans, one bringing in air and one sucking it out, but that is not so good in cold weather.
We have a little bracket that keeps our rear door cracked and locked, and weather shields on the front windows so we leave them open about an inch in all weather and temperature. The fridge ventilation route has been setup to provide enough circulation to keep the air moving in warm weather - believe that or not!
Fear not - insulation is on the way! But the focus was on getting the van usable - so bed and board racks prioritised! We were pretty much looking to follow the same process as shown in @bitingmidge 's build - I take it the stretch carpet was also from Car Builders?
Great news! With all that lovely work it’s a shame not to finish it! I’m looking forward to seeing how it evolves.
I bought the “carpet” from a wholesaler https://fabtex.com.au near Jacobs Well south of Brisbane, but if you are dealing with CarBuilders it’s the same product or similar, and their service is excellent. If you haven’t done it before, and have a compressor, a 20 litre drum of adhesive and a bit of solvent is about the same price as half of the spray cans you’ll need.
There’s a lot of satisfaction to be had getting it on nicely - there is a ton of info online, but give me a shout if you need any info.
