Use LCD from 3d printer
Hello,
I have an LCD from an old 3d printer. I would like to use it if possible. I found info on the top 14 pins
and how to map the pins from there to the rambo pins.
However, I don’t have the pin description for the 2x13 connector to the ribbon cable from the interface. Is there anyway I can do this? or should I just buy another LCD.
Thanks in advance!
Do you know if it is supported by Marlin, or what the name of it is?
The 3d printer was ran on Marlin. It was an Mbot Cube 2. The LCD screen is a BYT2004A. The interface board is and Mbot one. I’ve emailed their support for help. But their support was never great.
The 2004 is commonly used in Marlin. The config value for that is:
REPRAP_DISCOUNT_SMART_CONTROLLER
There are some more details about that here: https://reprap.org/wiki/RepRapDiscount_Smart_Controller
It looks a little different than your set up though, because of the buttons and the ribbon cable.
Honestly, unless you are in love with this screen, a replacement would be well worth it. I am a cheapskate, and I would get a new one. The reprap full discount display is a bit easier to use, and still costs very little.
