Hi everybody,
now I have a fully functional mpcnc and it seems to me quite perfect!!! I’m very happy about this thing. Thanks to Ryan once again!
But…
I have a problem, in the middle of a work it happens that in repetier host I see the following message: “Communication timeout - reset send buffer block”.
I have a 3m usb cable connected directly to the pc port…
here is a complete listing.
18:57:10.235 : start
18:57:10.235 : echo:Marlin1.0.2
18:57:10.235 : echo: Last Updated: Feb 6 2016 11_25_1521:33:00 | Author: PID, ALLTED
18:57:10.235 : Compiled: Feb 6 2016
18:57:10.235 : echo: Free Memory: 3190 PlannerBufferBytes: 1232
18:57:10.251 : echo:Hardcoded Default Settings Loaded
18:57:10.251 : echo:Steps per unit:
18:57:10.251 : echo: M92 X200.00 Y200.00 Z4535.44 E200.00
18:57:10.251 : echo:Maximum feedrates (mm/s):
18:57:10.251 : echo: M203 X195.00 Y195.00 Z8.70 E25.00
18:57:10.251 : echo:Maximum Acceleration (mm/s2):
18:57:10.251 : echo: M201 X400 Y400 Z55 E800
18:57:10.251 : echo:Acceleration: S=acceleration, T=retract acceleration
18:57:10.251 : echo: M204 S400.00 T800.00
18:57:10.267 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
18:57:10.267 : echo: M205 S0.00 T0.00 B20000 X4.00 Z0.40 E5.00
18:57:10.267 : echo:Home offset (mm):
18:57:10.267 : echo: M206 X0.00 Y0.00 Z0.00
18:57:10.267 : echo:PID settings:
18:57:10.267 : echo: M301 P12.03 I0.60 D60.60
18:57:10.267 : echo:Filament settings: Disabled
18:57:10.267 : echo:Z-Probe Offset (mm):
18:57:10.267 : echo: M851 Z0.00
18:57:13.902 : echo:SD init fail
18:57:13.996 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:MPCNC EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
18:57:14.012 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
18:57:14.012 : echo:Active Extruder: 0
18:57:14.012 : Error:No Checksum with line number, Last Line: 11
18:57:14.012 : Resend: 12
18:57:14.027 : echo:Active Extruder: 0
18:57:21.153 : Printer reset detected - initalizing
18:57:21.153 : start
18:57:21.153 : echo:Marlin1.0.2
18:57:21.153 : echo: Last Updated: Feb 6 2016 11_25_1521:33:00 | Author: PID, ALLTED
18:57:21.153 : Compiled: Feb 6 2016
18:57:21.153 : echo: Free Memory: 3190 PlannerBufferBytes: 1232
18:57:21.169 : echo:Hardcoded Default Settings Loaded
18:57:21.169 : echo:Steps per unit:
18:57:21.169 : echo: M92 X200.00 Y200.00 Z4535.44 E200.00
18:57:21.169 : echo:Maximum feedrates (mm/s):
18:57:21.169 : echo: M203 X195.00 Y195.00 Z8.70 E25.00
18:57:21.169 : echo:Maximum Acceleration (mm/s2):
18:57:21.169 : echo: M201 X400 Y400 Z55 E800
18:57:21.169 : echo:Acceleration: S=acceleration, T=retract acceleration
18:57:21.184 : echo: M204 S400.00 T800.00
18:57:21.184 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
18:57:21.184 : echo: M205 S0.00 T0.00 B20000 X4.00 Z0.40 E5.00
18:57:21.184 : echo:Home offset (mm):
18:57:21.184 : echo: M206 X0.00 Y0.00 Z0.00
18:57:21.184 : echo:PID settings:
18:57:21.184 : echo: M301 P12.03 I0.60 D60.60
18:57:21.200 : echo:Filament settings: Disabled
18:57:21.200 : echo:Z-Probe Offset (mm):
18:57:21.200 : echo: M851 Z0.00
18:57:24.825 : echo:SD init fail
18:57:24.919 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:MPCNC EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
18:57:24.919 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
18:57:24.934 : echo:Active Extruder: 0
19:02:26.188 : Communication timeout - reset send buffer block
19:02:38.433 : Error:checksum mismatch, Last Line: 214
19:02:38.433 : Resend: 215
19:02:38.449 : Error:Line Number is not Last Line Number+1, Last Line: 214
19:02:38.449 : Resend: 215
19:03:18.559 : Communication timeout - reset send buffer block
19:03:38.703 : Error:Line Number is not Last Line Number+1, Last Line: 218
19:03:38.703 : Resend: 219
19:03:38.718 : Error:Line Number is not Last Line Number+1, Last Line: 218
19:03:38.718 : Resend: 219
19:03:38.744 : Error:Line Number is not Last Line Number+1, Last Line: 224
19:03:38.744 : Resend: 225
19:03:38.754 : Error:No Line Number with checksum, Last Line: 224
19:03:38.754 : Error:Line Number is not Last Line Number+1, Last Line: 224
19:03:38.754 : Resend: 225
19:03:38.784 : Error:checksum mismatch, Last Line: 229
19:03:38.784 : Resend: 230
19:03:38.794 : Error:Line Number is not Last Line Number+1, Last Line: 229
19:03:38.794 : Resend: 230
19:03:38.984 : Error:checksum mismatch, Last Line: 232
19:03:38.984 : Resend: 233
19:03:38.994 : Error:No Line Number with checksum, Last Line: 232
19:04:45.970 : Lavoro di stampa finito alle 07/02/2016 19:04
19:04:45.970 : Tempo di stampa: 6m:48s
19:04:45.970 : Linee inviate: 152
Do you know how to remove this problem?
Many thanks
Gianluca
