Upgrading FluidNC - help
As I am not doing this often I want to make sure I make it the right way and I am not losing the relevant changes I did until now.
I believe the most important changes I did were:
  • adding code for using the laser
  • adjust the y steps per mm
what do I need to backup and eventually reload after teh upgrade?
Thanks in advance
You just need your config.yaml file.
Thanks for the quick reply. Update went smoothly but as usual I had to use esptool rather than the web installer. I also took the opportunity to update fluidtouch.
Testing some dragknife operations later today.
