Here is my Post Processor Info If anyone can help me
- Emco VMC 100 Vectric output configuration file
- History
- Who When What
- Mark 02/01/2009 Written
POST_NAME = “Emco VMC 100 ATC (mm)(*.nc)”
FILE_EXTENSION = “nc”
UNITS = “MM”
- Line terminating characters
LINE_ENDING = “[13][10]”
- Block numbering
LINE_NUMBER_START = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999980
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.3]
VAR Y_POSITION = [Y|C|Y|1.3]
VAR Z_POSITION = [Z|C|Z|1.3]
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.3]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.3]
VAR X_HOME_POSITION = [XH|A|X|1.3]
VAR Y_HOME_POSITION = [YH|A|Y|1.3]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
VAR SAFE_Z_HEIGHT = [SAFEZ|A|Z|1.3]
- Block definitions for toolpath output
- Commands output at the start of the file
begin HEADER
“%0004”
“[N] G54 T0[T]0[T] G00 [S] [XH] [YH] [ZH] M03”
- Commands output for rapid moves
begin RAPID_MOVE
“[N] G00 [X] [Y] [Z]”
- Commands output for the first feed rate move
begin FIRST_FEED_MOVE
“[N] G01 [X] [Y] [Z] [F]”
- Commands output for feed rate moves
begin FEED_MOVE
“[N] G01 [X] [Y] [Z]”
- Commands output at toolchange
begin TOOLCHANGE
“[N] G00 Z40.000 X0.000 Y10.000 M00”
“[N] T0[T]0[T] G00 [ZH] [XH] [YH] M00”
- Commands output for a new segment - toolpath
- with same toolnumber but maybe different feedrates
begin NEW_SEGMENT
“[N] G00 [SAFEZ]”
“[N] [S] M03”
- Commands output at the end of the file
begin FOOTER
“[N] G00 Z40.000 X0.000 Y10.000”
“[N] G53 T0000 M30”
Thanks for any help
