I just put on my 3.5W Banggood Laser, wired the TTL to pin 45, and it works using M3 commands to vary the laser intensity. The problem I have is it doesn’t work in Lightburn. Lightburn controls the everything with the exception of turning the laser on and off. Has anybody else had this problem and/or has a solution? I wrote lightburn and asked, but haven’t received a response yet.
You need to use the grayscale dithering option to enable variable power.
Also just picked up a 3.5W laser. Do you have a link to the instruction you followed to set it up.
Here’s the basic thread I used to get it going.
So to summarize:
- I have a RAMBO board. I had to update the firmware and make sure the laser/spindle was enabled. Then reflash it back on the RAMBO
- I used the this mount https://www.thingiverse.com/thing:2614283
- Hooked the TTL Positive line to RAMBO pin 45 and the negative to the pin in the picture of the thread above.
- I had to cut the lasers wires between the control board and the laser in order to splice in some longer wires.
- Make sure to where laser safety glasses
- I've been using the M3 Oxxx to get it fired up
- Makes a bunch of stinky smoke :-)
