George , I don’t have LCD . But used that file and worked . Running Windows 10 . Please don’t get too discoraged you are very close.
I am usually able to reply anytime time, so if you find something you don’t understand in the instructions or something doesn’t work as it should post it in here and I can usually help within a few minutes.
We can get you rolling one way or another.
Thank you Ryan.
If you have been reading along on this thread, you see a post that mentioned Estlcam loaded its firmware on my Arduino board. One of the posts said to reflash the board. I followed the instructions and got an error message.
Another post said try Run as Admin, so I did and still get an error message.
I have X, Y, and Z wires unplugged from board. Board is powered up and UsB is plugged in.
The Ardunio drivers were reinstalled, and the computer sees the board.
RC7_MPCNC_LCD_9916 is the firmware with the U8glib.h library I am trying to flash to the board.
Note: I do not have a LCD screen on the board.
Does the matter, I did not see another firmware option to pick.
I also got rid of the Repetier Host Server and installed just Rpetier host.
So I will need help getting that to recognize the CNC machine in the next step.
Thanks again for taking the time.
George
What error message and when did you get it?
Do you have a computer to flash it with windows 8 or 10 on it? Windows 7 could be the whole problem here.
no only windows 7.
Non of that was mentioned when I bought the kit.
I can not go out and buy another computer just for this. this is getting out of hand here!
I got the error message when I tried to upload the Marlin firmware that you told me I had to reflash due to Estlcam loading its firmware on Arduino board.
This ridiculous.
I need real help to get this up and running.
I was close and now It Does Nothing at ALL!
I understand you are frustrated but I sent it to you flashed and ready to go. I am trying to help you flash it back to the way I ship it.
I am not asking you to buy a new computer, simply asking if you had another to try. Windows 7 should work but clearly you are having issue. You haven’t said what error message you are getting so I really can’t help until you do.
Feel free to send it in and I will gladly flash it for you.
I am available usually 12 hours a day to help out. I understand you are frustrated so I am sending this from the grocery store. If you want to tell me the error message and when it happens I will be at a computer to help you in about 20 minutes. A screen shot might help as well.
So I have tried to reflash the Marlin to the board and get an error message.
I have the motor wires unplugged, I included the U8glib library, and click the upload button on the arduino software window.
I have enclose some screen shots.
My computer sees the Arduino board and says it is working properly.
When I open the Repetier Host software and click connect, the lights on the board blink, but it does nothing. ( when I unplug the board from computer and power and re attach the motors, then power back up ) So there is a connection of sorts, just not right.
Look at the screen shot to see if I am even using the right Marlin, I do not have a LCD screen for the MPCNC/ board.
I will post the error message in next post. There is a botton that says copy error message.
This is the error message
Main info is last paragragh, and last line above that.
It says permission denied, and error compiling
Arduino: 1.8.2 (Windows 7), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware -tools C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\tools-builder -tools C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr -built-in-libraries C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\libraries -libraries C:\Users\MsMia\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10802 -build-path C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046 -warnings=none -build-cache C:\Users\MsMia\AppData\Local\Temp\arduino_cache_18201 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr -verbose C:\Users\MsMia\Downloads\RC7_MPCNC_LCD_9916\RC7_MPCNC_LCD_9916\RC7_MPCNC_LCD_9916.ino
C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\arduino-builder -compile -logger=machine -hardware C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware -tools C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\tools-builder -tools C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr -built-in-libraries C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\libraries -libraries C:\Users\MsMia\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10802 -build-path C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046 -warnings=none -build-cache C:\Users\MsMia\AppData\Local\Temp\arduino_cache_18201 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr -verbose C:\Users\MsMia\Downloads\RC7_MPCNC_LCD_9916\RC7_MPCNC_LCD_9916\RC7_MPCNC_LCD_9916.ino
Using board ‘mega’ from platform in folder: C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\arduino\avr
Using core ‘arduino’ from platform in folder: C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\arduino\avr
Detecting libraries used…
“C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\arduino\avr\cores\arduino” “-IC:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\arduino\avr\variants\mega” “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\RC7_MPCNC_LCD_9916.ino.cpp” -o “nul”
“C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\arduino\avr\cores\arduino” “-IC:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\arduino\avr\variants\mega” “-IC:\Users\MsMia\Documents\Arduino\libraries\U8glib\src” “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\RC7_MPCNC_LCD_9916.ino.cpp” -o “nul”
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\M100_Free_Mem_Chk.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\MarlinSerial.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\Marlin_main.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\Sd2Card.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\SdBaseFile.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\SdFatUtil.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\SdFile.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\SdVolume.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\blinkm.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\cardreader.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\configuration_store.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\dac_mcp4728.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\digipot_mcp4451.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\endstops.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\mesh_bed_leveling.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\planner.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\planner_bezier.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\printcounter.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\qr_solve.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\servo.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\stepper.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\stepper_dac.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\stepper_indirection.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\stopwatch.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\temperature.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\twibus.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\ultralcd.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\utility.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\vector_3.cpp
Using cached library dependencies for file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\watchdog.cpp
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\U8glib.cpp
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\chessengine.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_bitmap.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_circle.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_clip.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_api.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_api_16gr.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_attiny85_hw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_common.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_fast_parallel.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_usart_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_no_en_parallel.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_parallel.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_port_d_wr.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_ssd_i2c.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_custom.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_std_sw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_sw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_t6963.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_uc_i2c.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_atmega_hw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_atmega_parallel.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_atmega_st7920_hw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_atmega_st7920_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_atmega_sw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_atxmega_hw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_atxmega_st7920_hw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_i2c.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_io.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_linux_ssd_i2c.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_msp430_hw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_null.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_psoc5_ssd_hw_parallel.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_raspberrypi_hw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_raspberrypi_ssd_i2c.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_std_sw_spi.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_cursor.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_delay.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_a2_micro_printer.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_flipdisc_2x7.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_gprof.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ht1632.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ili9325d_320x240.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ks0108_128x64.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_lc7981_160x80.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_lc7981_240x128.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_lc7981_240x64.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_lc7981_320x64.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ld7032_60x32.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_null.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_pcd8544_84x48.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_pcf8812_96x65.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_sbn1661_122x32.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1306_128x32.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1306_128x64.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1306_64x48.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1309_128x64.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1322_nhd31oled_bw.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1322_nhd31oled_gr.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1325_nhd27oled_bw.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1325_nhd27oled_bw_new.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1325_nhd27oled_gr.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1325_nhd27oled_gr_new.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1327_96x96_gr.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1351_128x128.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_ssd1353_160x128.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_st7565_64128n.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_st7565_dogm128.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_st7565_dogm132.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_st7565_lm6059.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_st7565_lm6063.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_st7565_nhd_c12832.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_st7565_nhd_c12864.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_st7687_c144mvgd.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_st7920_128x64.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_st7920_192x32.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_st7920_202x32.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_t6963_128x128.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_t6963_128x64.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_t6963_240x128.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_t6963_240x64.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_tls8204_84x48.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_uc1601_c128032.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_uc1608_240x128.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_uc1608_240x64.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_uc1610_dogxl160.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_uc1611_dogm240.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_uc1611_dogxl240.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_uc1701_dogs102.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_dev_uc1701_mini12864.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_ellipse.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_font.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_font_data.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_line.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_ll_api.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_page.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb14v1.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb16h1.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb16h2.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb16v1.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb16v2.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb32h1.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb8h1.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb8h1f.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb8h2.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb8h8.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb8v1.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pb8v2.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pbxh16.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_pbxh24.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_polygon.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_rect.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_rot.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_scale.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_state.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_u16toa.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_u8toa.c
Using cached library dependencies for file: C:\Users\MsMia\Documents\Arduino\libraries\U8glib\src\clib\u8g_virtual_screen.c
Generating function prototypes…
“C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\arduino\avr\cores\arduino” “-IC:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\arduino\avr\variants\mega” “-IC:\Users\MsMia\Documents\Arduino\libraries\U8glib\src” “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\RC7_MPCNC_LCD_9916.ino.cpp” -o “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\preproc\ctags_target_for_gcc_minus_e.cpp”
“C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\tools-builder\ctags\5.8-arduino11/ctags” -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\preproc\ctags_target_for_gcc_minus_e.cpp”
Compiling sketch…
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\M100_Free_Mem_Chk.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\MarlinSerial.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\Marlin_main.cpp.o
“C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\arduino\avr\cores\arduino” “-IC:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\arduino\avr\variants\mega” “-IC:\Users\MsMia\Documents\Arduino\libraries\U8glib\src” “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\RC7_MPCNC_LCD_9916.ino.cpp” -o “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\RC7_MPCNC_LCD_9916.ino.cpp.o”
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\Sd2Card.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\SdBaseFile.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\SdFatUtil.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\SdFile.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\SdVolume.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\blinkm.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\cardreader.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\configuration_store.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\dac_mcp4728.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\digipot_mcp4451.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\endstops.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\mesh_bed_leveling.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\planner.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\planner_bezier.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\printcounter.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\qr_solve.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\servo.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\stepper.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\stepper_dac.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\stepper_indirection.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\stopwatch.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\temperature.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\twibus.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\ultralcd.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\utility.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\vector_3.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\sketch\watchdog.cpp.o
Compiling libraries…
Compiling library “U8glib”
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\U8glib.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\chessengine.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_bitmap.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_circle.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_clip.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_api.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_api_16gr.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_attiny85_hw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_common.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_fast_parallel.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_hw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_hw_usart_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_no_en_parallel.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_parallel.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_port_d_wr.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_ssd_i2c.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_st7920_custom.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_st7920_hw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_st7920_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_std_sw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_sw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_t6963.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_arduino_uc_i2c.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_atmega_hw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_atmega_parallel.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_atmega_st7920_hw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_atmega_st7920_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_atmega_sw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_atxmega_hw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_atxmega_st7920_hw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_i2c.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_io.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_linux_ssd_i2c.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_msp430_hw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_null.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_psoc5_ssd_hw_parallel.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_raspberrypi_hw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_raspberrypi_ssd_i2c.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_com_std_sw_spi.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_cursor.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_delay.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_a2_micro_printer.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_flipdisc_2x7.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_gprof.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ht1632.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ili9325d_320x240.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ks0108_128x64.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_lc7981_160x80.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_lc7981_240x128.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_lc7981_240x64.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_lc7981_320x64.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ld7032_60x32.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_null.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_pcd8544_84x48.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_pcf8812_96x65.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_sbn1661_122x32.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1306_128x32.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1306_128x64.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1306_64x48.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1309_128x64.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1322_nhd31oled_bw.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1322_nhd31oled_gr.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1325_nhd27oled_bw.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1325_nhd27oled_bw_new.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1325_nhd27oled_gr.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1325_nhd27oled_gr_new.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1327_96x96_gr.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1351_128x128.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_ssd1353_160x128.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_st7565_64128n.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_st7565_dogm128.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_st7565_dogm132.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_st7565_lm6059.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_st7565_lm6063.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_st7565_nhd_c12832.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_st7565_nhd_c12864.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_st7687_c144mvgd.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_st7920_128x64.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_st7920_192x32.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_st7920_202x32.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_t6963_128x128.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_t6963_128x64.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_t6963_240x128.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_t6963_240x64.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_tls8204_84x48.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_uc1601_c128032.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_uc1608_240x128.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_uc1608_240x64.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_uc1610_dogxl160.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_uc1611_dogm240.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_uc1611_dogxl240.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_uc1701_dogs102.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_dev_uc1701_mini12864.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_ellipse.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_font.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_font_data.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_line.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_ll_api.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_page.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb14v1.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb16h1.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb16h2.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb16v1.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb16v2.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb32h1.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb8h1.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb8h1f.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb8h2.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb8h8.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb8v1.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pb8v2.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pbxh16.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_pbxh24.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_polygon.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_rect.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_rot.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_scale.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_state.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_u16toa.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_u8toa.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\libraries\U8glib\clib\u8g_virtual_screen.c.o
Compiling core…
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\wiring_pulse.S.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\WInterrupts.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\hooks.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\wiring.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\wiring_analog.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\wiring_digital.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\wiring_pulse.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\wiring_shift.c.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\CDC.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\PluggableUSB.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\Print.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\Stream.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\Tone.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\USBCore.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\WMath.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\WString.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\abi.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\main.cpp.o
Using previously compiled file: C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\new.cpp.o
“C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\core.a” “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\wiring_pulse.S.o”
“C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\core.a” “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\WInterrupts.c.o”
“C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\core.a” “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\hooks.c.o”
“C:\Users\MsMia\Desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\core.a” “C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\wiring.c.o”
c:\users\msmia\desktop\arduino-1.8.2-windows\arduino-1.8.2\hardware\tools\avr\bin…/lib/gcc/avr/4.9.2/…/…/…/…/avr/bin/ar.exe: unable to rename ‘C:\Users\MsMia\AppData\Local\Temp\arduino_build_628046\core\core.a’; reason: Permission denied
Using library U8glib at version 1.19.1 in folder: C:\Users\MsMia\Documents\Arduino\libraries\U8glib
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
That is not how you add the ug8lib.
You should not be adding any line to the firmware.
If you have added the library as shown in the step by step you should see this. It should only show 1 but I am testing two versions.
[attachment file=32629]
If you have that showing, start at the step that says, “Tools-Board-Mega 2560”
In this tutorial,
Hello Ryan and everyone that has assisted me in my quest to get this thing running. A Big Thank You.
I finally got the Arduino board reflashed. The Windows Fire Wall was what was blocking things, giving me the Premission Denied. Found someone on the Arduino Forum mention it reguarding permission denied.
So I reflashed and opened up Repetier Host. manually MPCNC moves in all the right directions now, using the manual control.
But when I hit the Home buttons for X, Y, and Z they move to mid back X rail and ceter Y, and the Z goes down into bed.
How do I zero X,Y,Z, because the program moves the gantry away from the material. And sends Z down into my waste board.
I am so excited I am so close, just need a little more fine tuning and practice.
Please bare with me and my very beginner mind, this is all new to me who has been a scroll sawer for many years.
Your welcome.
You can’t use the home buttons. At least not without endstops, most of us do not use them.
If you’re axis are moving the wrong way, simple power down, unplug, and flip the plug over for the offending axis. https://www.v1engineering.com/reversing-the-axis-direction/
Typically X positive moves you right, Y positive moves you back/away, Z positive moves the cutter up.
Ok I flipped the plugs on the board around and it seems to be moving in the right directions. am I placing the Z (bit) on the waste board or top of material. I seems to be lifting too high now.
Also on a separate note. The Z was not turn the screw to much before I flipped the plugs and when I tried to tighten it the fins covering the screw cracked off.
How can I get a replacement, did not see on the parts page. need to order one or two more just in case.
Thanks
Got Repetier Host connected to cnc machine. Manual controls move in all correct dierctions.
Tried a saved cut program and the Z lifts up and runs into the back rail. hit emergency stop and move it back.
Made a new program from scratch. Machine unplugged. Open Estlcam specify size, cuts, thickness. Saved.
Closed Estlcam. Open RH, plug in machine. Open program. hit connect in RH, lights on board blink. Check preview and machine moves manually. turn on router, hit start button in RH.
Machine moves up, then to middle of work piece and stops.
Please tell me what I am missing.
I thing I am getting closer, but just out of reach
P.S. when I opened Estlcam there was a window pop up that said there was an upgrade to v.10.35 from 10.18
Is this going to fix having to use both programs to make something.
Thank you for being patient with me still have a lot to learn with all of this.
George
Do you get any error messages at the bottom of the screen in repetier host?
Does my gcode from the beginner or intermediate tutorial work?
Using your own gcode makes this to hard to diagnose, or you at least have to attach it here.
I will try the vicious1 logo, test design and see what it does.
And I will copy my design up here for you to check out.
Thank you
Yeah see how that goes first then if you have to you can attach the file, please don’t copy and paste it.
I have a feeling it is just a setting somewhere in your gcode. If repetier moves it fine, then that is pretty much your only other possibility. Usually an inch to mm thing, triple check your repetier screens to mine and turn on the grid so you can check, the output is mm/min, not second is another big one.
Well, When I was doing it wrong, using Estlcam. Home was ing the lower left corner of machine.
Along the front edge of my table, so I could reach to change bits and such. All my wiring was done with that in mind.
Now after the gantry running into the rails a dozen time or so, I figured out it wants my Zero/Home to be the opposite corner farthest from me, in the back corner along the wall.
It is still dragging the bit through the foam board. But something even weirder happened. your test design, Viciuos Logo it is correct on the screen, but it cut it mirrored/backwards.
See picture enclosed.
I am at a loss, I am sad, but laughing because if I don’t I would be very pissed off.
Please help. I hope this is some thing really easy to fix.
Getting closer, Sorry to be so much trouble.
When we get this working it will be totally awesome!
George
All you have to do is flip the x axis plug. Be sure to unplug all power first.
Your machine can be oriented in any way you want but how the file is generated is what determines which point should be your starting point. My files are generated with the starting point in the leftmost closest corner.
That is how I had it, when I was using just Estlcam.
Now when I make the Program in Estlcam and open it in RH, it wanted to use the opposite diagonal corner. Which could also be the left corner if I turn my machine around. But then all the wiring will be in the front and not the back which is what I would like, out of the way.
I will try after dinner and see if flipping the X plug works.
