So I am trying to do some test runs on my CNC but am having trouble understanding how to create a tool in Estlcam with the proper parameters (or properly define my tool path)
My goal at this time is to create a foam cutter (needle tool). So I created the attached tool and set the following tool path. I have through cuts which is the shown tool path parameters. I will also have score cuts where for the purpose of the test I defined as 5mm. When creating the tool path I used the engrave option.
When I execute the code it goes through the same path several times (I believe it was 3 or 4 times) before it goes on to the next path. I only need it to go through once. What am I doing wrong?
Thanks
