TMC 2209 stopped working
After completing a carve that was a disaster I found that my X axis wouldn’t home properly. The resulting carve (see picture) I am assuming is the result of this error. What I found was the X1 axis stepper motor was not receiving any power. After checking all wiring and replacing the stepper with a spare I still had no power to the stepper. I had a spare TMC 2209 that I tried and it fixed the problem……X axis now has power to all steppers and homing is working.
What would cause the TMC 2209 to stop functioning?
Am I correct that the stepper motor not functioning caused the carve problems? The carve is actually 2 copies (or more) of a tree displaced by about 10mm! Is that because each stepper was at a different X coordinate? I will be trying a test cut soon. Just trying to understand what happened.
Here is a picture of the carve….
Stepper motors almost never fail. The wiring can fail, but the motors almost never are the reason.
What type of controller do you have on your MPCNC?
One helpful thing would have been for you to pull diagnostics so more about the failure can be understood. Since you’ve replaced the driver, there’s no need for that.
To answer your question about what kills drivers- there are a few ways I know of that have a good probability of destrying a driver:
  • Disconnect the driver while the machine is on. This can be by unplugging a stepper, or a wire extension coming loose.
  • Manually move the axis at a decent rate of speed while the machine is off (or the steppers are disabled). This is more a problem on flying Z 3D printers- but we have seen it on CNCs as well.
  • ESD events can kill anything electronic.
I’m using a Jackpot. I was showing the mpcnc to my som in law and moved the axis when it was off. Guess I was the cause of the failure!
I checked the wiring first. The stepper motor and TMC were easy to check since i had spares available. Once a new TMC was plugged in, everything worked.
Learn something new each day……never too old to learn!
It was frustrating since I had just completed a really nice carve on a cutting board the day before. Hopefully a test run will show everything is fixed.
What diagnosis would I use to trouble shoot this problem?
For FluidNC, if you’re having trouble run $SS from the terminal and cut/paste those here in the forum.
Still having trouble with this issue. I have apparently lost another TMC 2209. the ) end stop ight is out, the machine will not move in either axis. Same symptoms I had previously but on a different axis. The last one was resolved by replacing the TMC 2209. Before I do that this time I want to try and determine what is burning the TMC 2209 out, if that is the problem. I did not move the axis manually and didn’t unplug anything. I had used it several times to surface some scrap wood and two cutting boards. I was preparing to surface another cutting board when it stopped working.
Here is my $SS
$G
$SS
[MSG:INFO: FluidNC v3.9.1 GitHub - bdring/FluidNC: The next generation of motion control firmware]
[MSG:INFO: Machine MPCNC]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (3.000,1223.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: X2 Neg Limit gpio.35]
[MSG:INFO: Axis Y (3.000,2443.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Y2 Neg Limit gpio.34]
[MSG:INFO: Axis Z (-100.000,200.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Z Neg Limit gpio.32:low]
[MSG:INFO: X2 Axis driver test passed]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Probe gpio.36:low]
ok
This symptom has nothing to do with TMC2209s, the endstop IO is buffered from the ESP-32 GPIO and doesn’t go through the stepper motor drivers.
Can you post a picture of your wiring, and showing the LEDs as it’s in this state?
If you manually toggle each of your limit switches one at a time, what do the LEDs on the Jackpot board do?
I don’t see any errors in that $SS, and in particular all of the stepper drivers are responding correctly.
It isn’t homing, but can you jog the machine in any direction on any axis?
All of the LEDS turn off when the limit switchs are triggered.
All of the steppers have power but do not respond to jogging.
More to come. Computer is acting up and not connecting to FluidNC
Standing by for more details, but in the meantime some questions:
Some questions/ observations that may have nothing to do with your issues:
What AWG is the power supply wiring going into the jackpot? It looks undersized to me.
Where do you normally install/route the SD extension cable pictured in the lower left? Is it in or out when the system is misbehaving?
Note the area I marked up in green. You really don’t want any wires in this area in order to have usable WiFi. Try to route the cables more in line with the yellow sketch.
If you pull the multi-connector endstop holder, with no connection at all, can you jog?
Have you tried jogging with gcode from the terminal, or are you only using the UI? Which version of UI?
 I bought the power supply from Ryan......whatever he supplies.
 The SD extension plugs into the SD card slot.  It is presently disconnected.  Plugging it back in has no effect on jogging.
 These cables were rerouted several weeks ago and have not been an interference issue.  I can try to move them but the cabling is very tight.  I see a major effort to clean up my wiring in the near future.
 No..jogging still not working.
 UI is version2.  I tried $H and $SS on the command line.  They return an error 500, web socket dead.
I was able to fix the end stop issue. It was a bad wire connection. But that fix didn’ change anything.
I also noticed that the alarm signal is on and will not reset. I also cannot make any choices on the movement ‘wheel’. There are no arrows shown.
More…the alarm just reset…now in idle. it also responded to $SS but it still will not jog. I am using my ipad and had to restart it. Back to alarm mode.
I think I fixed it.
When my computer went out I tried using my IPad. Apparently my IPad and CNC do not like each other. Once I got my computer (a really old Surface laptop) running and used it to connect to the Jackpot all the problems disappeared.
Does using an iPad require some additional steps to interface with the Jackpot?
Nope, I use an iPad and iPhone without issues.
-unless maybe it’s an older iOS/safari version?
You have to be sure you’re not in the portal login browser that pops up on iOS, or you’ll have a crippled web UI.
I knew you used an iPad. That’s why I gave it a try but obviously I don’t know what I am doing.
I’m not sure what you mean but I will be trying to learn what you are talking about. I’ve had an iPad for a long time but I apparently don’t know how to really use it.
BTW…Thanks for your help. You, and this forum have taught me a lot.
Not just iPads, but most OS will detect the FluidNC AP server and present a “login” screen.
This has limited functionality, so you can’t do everything from that browser.
After I connect, whether it is iPad, Mac, Linux, or Windows- I always close the OS opened portal signon browser and then open a fresh browser. Only after that do I go back to the web UI and use the machine.
Closing older topics, to fight spambots
