Hi everyone,
I am just finishing settin up my MPCNC latest version and i am facing a problem with the Z assembly. I am using an 8mm threaded rod.
As soon as i put the threaded rod through the Z lower bracket (the one with the bearing inside), it puts a very very slight amount of force on the rod because the rod is not perfectly centered with the bearing center. Maybe by a half millimeter even less… but this slight force causes the rod to lock in place and not spinning anymore or with a huge amount of force that the Z motor cannot handle.
When i remove all the Z Axis and i put the rod inside the the middle assembly i constat 2 things:
- when totally aligned i can spin it correctly (screw and unscrew)
- as soon as i put a slight force with a single finger on the back of the rod then its impossible to spin it anymore (its the same direction needed to put the rods in the bearing axis when everything is in place)
- if i put the same force (or more) on the front of the rod it always spin correctly
So is someone ever faced the same problem ? Did i assembled something wrong ? A known problem with 8 mm threaded rod or a part design issue ( nut lock off center) ?
Thanks for your help guys, hope that i can sort this out fast
