Something different-
This whole escapade has got me thinking about how to put a 150W CO2 tube on a Primo base ā¦
Some more laser testing today, while Toddler was on nap.
Reprinted the mount, shortened the fulcrum to 27mm (still allows access by tools for attachment to the gantry)
I had the router removed in order to mount the laser mount, and didnāt replace.
Ran the same Raster50/50 test as the other day, and saw some improvement in the shakiness. Not perfect.
Once Iām back from school pick-up, going to redo the gcode down to 20mm/s speed, and adjust power accordingly. Also change the overscan a bit.
If I can get good logo engravings and a full cut for the coin (in 3mm maple) - my āmakers markā that I embed in the bigger pieces- Iāll be kinda- ish happy.
Ok, so spent some time yesterday redoing the laser mount- went for a slightly remixed version of this one- (to add neje mount holes)
Thanks @CNCLuke !!!
And then threw a bunch of tests at it. Completely eliminated the wobble, everything is crisp.
That coin is a raster image done at 125mm/s, 80% power single pass. I honestly meant to do 25mm/s but fat fingered the keys apparently.
Getting happier
Iām jealous. I want to be able to do that. Maybe in 6mo from now, I can.
Havenāt forgotten about you
Once I get a few more tests done, Iāll write something up.
Having a couple issues with NEJE customer services at the moment- laser isnāt performing as well as it should/could be .
Thanks
Donāt worry about me. Iām living vicariously through you. Iām still slowly building my machine.
Just had some guy on NEJE group treat me like an idiot because I told him my laser PWM isnt grbl $30 for max, but 0-255 in Marlin
Told me Marlin doesnāt run lasers.
Problem is, heās the main group neje contact I need for troubleshooting before a warranty return.
Wants me to use āproperā software lol
How about power with the test button, does the E40 has one ? A40640 comes with a small circuit with fire test button, if so does a press on it seems to burn at full power ?
I have it hooked up with that board.
But tell me- how do you judge āfull powerā of something you have no frame of reference for and donāt look at without 5OD of eye protection
I mean- I hit the test button while the lr3 makes a small square- thus taking the pwm control out of the equation- and it burns a square. Itās a thin stripe. It takes 4 repeats to get through a 3mm piece of Baltic birch plywood, which is 2 more than advertised.
It was more his insistence that I had the wrong firmware and had set it up incorrectly- he scoffed at S255 being our 100%, and said I needed a $30 value - while he blatantly doesnāt understand the firmware
Ok, got one more client build to get out the door, but I had to run a quick engrave test for a Christmas present Iām going for the wife. Her monogram
E40 laser, 200/min, 80%, variations with and without border line and a couple different scripts.
What is your V1 firmware version / release, did you recompile it from source ?
@vicious1 does the last firmwares have LASER_FEATURE already defined by default ?
Iām using the nightly from 3 weeks ago
Whatās the issue? My laser problems? They are not a V1 issue- Iām 98% sure I have a faulty unit based on my specs being half what other people report.
After looking at your LR3 and your fold-up table I am now 100% sure that I need a Lowrider as well⦠Might even consider ditching the MPCNC to save the space. I really really need to measure my potential workspace.
Warning you up front- this stuff is so much fun, I doubt Iāll use the folding table, lol.
Told my colleague the same thing that is is basically only there to tell my wife that I could fold it up.
About to batch a few more tins of my cutting board/wood conditioner, and Iāve lost my labels. Also- didnāt really like them, just didnāt have āimpactā
So I pushed the file into lightburn, and did this: 50mm/second, 50% power. Took 23 minutes because I forgot to do all groups at once so it rastered text individually
Black anodized aluminum tin, 4oz. I fill them with a 3:1:1 blend of mineral oil, coconut oil and beeswax. $1.39 for tin and ingredients, āretailā for $15 if bought with a board, $18 if separate.
I really need to learn from you guys when it comes to making money⦠
My boss wants to engrave our schoolās iPads with our Logo since a few have been stolen and said I could do it and bill the school for the work. I am kinda torn. If something goes wrong Iād be cutting holes in 500⬠hardware⦠-_- But on the other hand: money.
