If you have no marlin screen that means your SKR board does not have my firmware either that is set up for marlin mode.
Can you give some more details of what you are doing and where boards and firmware you are using. At this point I will have to start guessing without more info.
Lr3 build with skr pro motherboard with endstops included I still need to cut out the MDF board to get it up for official cutting.
This is the same system I’m using from the lr2 I believe I just flashed it to get the endstops.
I built a lr2 and I am getting on board with the lr3 . Pretty much all of the firmware setup are from my lr2 so I’m transitioning. I purchased all of these from. Before with a functional lr2 I apologize if it seems a bit of a lot
You currently have an LR2 and you want to build an LR3?
I am asking because the boards do not have my firmware on them. If you have an LR2, I am not sure how it ran because it is not my firmware for either machine.
Amazon stuff won’t have V1 firmware on though, but it can be installed. That may be a good idea. The V1 firmware on the TFT is a good idea.
Oh and the Amazon links are weird when you aren’t in the USA, they get translated to something close in Canada (Or wherever). Usually the same thing, but sometimes not so much.
No, Judging by your screen shots I am fairly certain you do not have the right firmware on the screen, and possibly the SKR pro as well. Your screen shot also shows a .cur file showing you have indeed flashed something.
It boils down to you do not have the right firmware on your board and or screen.
Items are from Amazon (Can) it’s basically what Dan has mentioned earlier. I’m trying to complete the Lr3 I’m at this stage now I wouldn’t be able to tell I’m a bit confused here now
I have the SKR Pro firmware, my TFT35 firmware is out of date, but I have a spare that I can load up and test out, and if it works right, I’ll email it, with install instructions.
So I have been following up with the wiring and also trying to figure out the movements on my LR3 but still I am unsuccessful.
Step 1 I loaded to my sd card to flash the firmware onto the motherboard the firmware on the SKR pro by downloading the DualLR firmware and.putting the firmware.bin on the microSD slot on the board.
The LCD will be able to print files (.gcode extensuon) if they are on the SD card in the TFT.
Step2.
I powered up the unit but still I was unable to get the v1 loading screen nor access to the Marlin portion in additional I have went to the bigtreetech option and tried moving just to make sure my wires I followed were correct but I got nothing working for me so far; how can I go about this matter ?
Marlin mode user the two gray cables connected between the lcd and the skr. The 5 pin black cable is only for tft mode. So check that those gray cables are correct.
After the skr pro flashes, it renames the file to firmware.cur. Do you see that on the sdcard?
Mine reads FIRMWARE.CUR I took out the sd card and now it’s just the board and the LCD screen functioning.
In this message I will provide images of the wiring to the board it’s possible I may got something wrong.
Please let me know if you need me to do anything else
I inserted SD card into the board and now it booted to the option between of . Now I’m just waiting I cannot key in anything right now .
What’s the particular that I need to have on the sd card
& How do I insert the information on the screen or from the board and how long doe you press to reset?
Just a step in the right direction I would need please .
